Cross reference: 2J183J SIC 460S
  • TVRepairNoobie
    • Feb 2015
    • 158
    Hi Everyone!
    Current project: Samsung LN32C450
    Will I be able to use the PCF1579-ND from digikey to replace the CM808 -2J 183J SIC 460S?
    https://www.digikey.com/products/en?keywords=PCF1579-ND
    Please advise, much appreciated!
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: Cross reference: 2J183J SIC 460S
    PCF1579-ND will not work on this TV. But, it can be used (to test if the TV will turn on after the part is replaced) to power on the TV with flickers.
    • R_J
      • Jun 2012
      • 9624
      You need .018 uf not .18 something like a P3512-ND should work but its obsolete This should work 495-7139-nd
      • TVRepairNoobie
        • Feb 2015
        • 158
        Thank you R_J!
        • TVRepairNoobie
          • Feb 2015
          • 158
          The part arrived this morning and installed. TV is saved!
          You're awesome R_J!.
          • connorcc2005
            Thermistor specs and cross reference
            by connorcc2005
            I'm getting some conflicting information and thought I'd toss it out to all of you for input.
            What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
            The physical diameter of the piece is 5.1mm measured with a caliper.
            Other than what you see in the pic, there is no other writing on the part.
            My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
            06-16-2022, 04:16 PM
          • raregtp
            Voltage regulator cross-reference
            by raregtp
            Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
            The first is:
            A1
            AS1117L-18
            B0640 25
            The second is:
            A1
            AS1117L-33
            B0640 28
            I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
            If anyone can assist...
            03-15-2020, 11:12 PM
          • jasko_jacker
            cross reference tps51285a
            by jasko_jacker
            I try to substitute the RT6575B with TPS51285A,
            it seems to work but it is slightly warmer, the board does not start due to other problems so but not sure if replacement is possible...
            12-07-2021, 01:49 PM
          • speaktorob
            Reference Nvidia GTX 980 ti - looking for a new shroud
            by speaktorob
            So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
            Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
            03-22-2024, 03:00 AM
          • Rhork
            Chip reference DA0G7BMB6D0 rév D HP Pavilion - 15-cs0006nf
            by Rhork
            I would like to know the reference of a QFN-20 because the reference marked on the chip does not give anything...
            PC Reference : HP Pavilion - 15-cs0006nf
            Motherboard : DA0G7BMB6D0 rev D
            Reference marked on the chip: AWVAIL
            Type : QFN-20
            I didn't find a boardview or repair schematics
            Thanks in advance...
            03-30-2022, 11:32 AM
