Sony KDL-40EX710 - Lightning strike and power surge
  • sat3182000
    • Jun 2017
    • 18
    • India
    Re: Sony KDL-40EX710 - Lightning strike and power surge
    Originally posted by dick_barton
    What voltage do you have with the meter probes set to DC placed across Pins 1 & 2
    Only one of the administrators can change a Post Title or contents of a post.
    8.7V volts,
    administrators made the changes already.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      What voltage do you have on Pin1 of IC6802 and chassis and then on Pin4 IC6800 and chassis?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Originally posted by sat3182000
        I did replace the component, still the same voltage on pin 1 and 2
        What part number did you replace it with?
        • sat3182000
          • Jun 2017
          • 18
          • India
          Replaced with 2561A, same part and then EL817
          IC6802 -> PIN 1 = -0.23V
          IC6800 -> PIN 1 = 0.01V
          IC6800 -> PIN 3 = -0.01V
          Thanks!
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            So the opto's should not be the problem.
            Can you check that IC6800 Pin 5 is at 12V and IC6800 Pin 4 is at 9V
            • sat3182000
              • Jun 2017
              • 18
              • India
              #26
              They are 0 Volts.
              How can I check if CXA3809M is switching? IC6501
              CXA3809M => IC6501 => Pin 20 => 10.2V
              Looks like the IC is not switching on with 10.2V
              I do not see any voltage at T6101 Pin5.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                • sat3182000
                  • Jun 2017
                  • 18
                  • India
                  #28
                  Its 10.5V, you must be right, Why is the 12V not turning on
                  • sat3182000
                    • Jun 2017
                    • 18
                    • India
                    #29
                    I am really tired, Thanks all for helping me out, I will post updates when I fix this board
                    • sat3182000
                      • Jun 2017
                      • 18
                      • India
                      #30
                      I have replaced the IC - CXA3809M => IC6501
                      Now the RED LED lights up and I have a 3 blink error code.
                      Can somebody help me please.
                      • sat3182000
                        • Jun 2017
                        • 18
                        • India
                        #31
                        Ah!! looks like the whole TV is bad... Checked the voltages again, There was no power going into the TCON board.. I jumped 12V to TCON now the Error code goes to 7.
                        Looks like a shot TCON Board. I am not sure what else I would have to change.. Is it worth changing it?
                        • pbig
                          advices for repairing Sony Bravia 32EX600 after lightning strike
                          by pbig
                          hi everyone,
                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                          - from connector CN6150 (15 poles)
                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                          06-28-2023, 02:43 AM
                        • Bardou Kari
                          HP EliteBook 840 G6 – no power after lightning strike
                          by Bardou Kari
                          I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                          – Charger is OK and 19V is present at the motherboard.
                          – No charging LED, no fan, no reaction.
                          – I don’t see any 3.3V or 5V near the coils.
                          – Battery is unplugged.
                          – I’m new to board repair but can use a multimeter.
                          I added a clear photo of the board.
                          Any idea where to start or what to check next?
                          Thanks a lot for your help!...
                          Yesterday, 10:45 AM
                        • karthur
                          Samsung UN60EH6000 wont come on after lightning strike.
                          by karthur
                          We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                          I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                          When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                          Here is what I have checked.
                          On the power supply board, 14pin connector:
                          1 :12.7 Vdc
                          3 :12.7
                          5 :12.7
                          7 :12.7
                          9 :0
                          11 :5.
                          13 :5....
                          11-01-2023, 06:18 PM
                        • MrCreosote
                          Lightning Strike: 55" TV dead: is display panel OK?
                          by MrCreosote
                          THE LIGHTNING:
                          This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                          Very close and probably a very strong EMP.
                          THE TV:
                          No standby LED. Some voltage from PSB (not totally dead).
                          But found a kit of ALL 4 circuit boards for $55.
                          At first thought, this will fix my TV.
                          But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                          08-16-2021, 10:27 PM
                        • pfl
                          ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                          by pfl
                          Hello Everyone.
                          This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                          It consists in :
                          • a power board were the full H bridge class D amplifier and main power rails are located
                          • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                          Power rails are ok.
                          human interface is working fine
                          Input levels are...
                          01-23-2024, 10:21 AM
