Sony KDL-40EX710 - Lightning strike and power surge
  • sat3182000
    • Jun 2017
    • 18
    • India
    Hi All,
    I am an electronics enthusiast and this is my second post, I recently received a TV that was struck by lightning.
    Model: KDL-40EX710
    The TV used to display the error code 7 blinks. The TV was sent to Sony for repairs but they trashed it as it was an obsolete model. Now after getting back the TV from them. The error codes have vanished. The red light comes on the relay clicks and then after 2 seconds it clicks back again.
    So I am trying to reverse engineer the power supply board.
    I have standby 3.3 V
    I am curious about the voltage in AC_OFF_DET. It shows 3.3 Volt but once I put a jumper on STBY3.3V to POWER_ON the AC_OFF_DET goes to 0V
    I feel this is not normal, I remember AC_OFF_DET being 2.3 ish to 2.8ish volts. Please help me out.
    I am trying to revive this TV.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: KDL-40EX710 - Lightning srike and power surge
    Do you have any pictures of your boards?
    • sat3182000
      • Jun 2017
      • 18
      • India
      Thank you for the quick response.
      Yes, I managed to get the circuit as well.
      Is there any way I could get the circuit of the main board of the same TV?
      ftp://helpedia.com/pub/temp/datashee...8-11_[SCH].pdf
      upload images
      • dskall
        • Oct 2016
        • 2905
        • usa
        Link does not open and picture not good enough to see much. I would be checking ac input protection components
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Looking at the schematic AC_Det going to 0V looks OK. Have you connected 3.3V to Power_On using a 1K resistor to see if the other supplies come up ie 12V, 24V
          • sat3182000
            • Jun 2017
            • 18
            • India
            Yes Other supply comes up for a second and then the relay clicks back off
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Found the data sheet for the CXA3809M-T6 and it says that if the AC in is OK then AC_DETOUT output is High so PH6302 input is not turned on so AC_DET output is also high as you first thought.
              Check all the components leading in to AC_DETIN.
              • sat3182000
                • Jun 2017
                • 18
                • India
                Re: Sony KDL-40EX710 - Lightning strike and power surge
                Status update, The relay latches when I put a jumper on STBY3.3V to POWER_ON. All other 12V does power up for a second.
                CXA3809M -> AC_DETIN gets a solid 5V
                CXA3809M -> AC_DETOUT get a solid 1.1V
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Can you post schematic. Link not opening
                  • sat3182000
                    • Jun 2017
                    • 18
                    • India
                    Please find the attachment
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Might check or remove vd6001 and vd6002
                      • sat3182000
                        • Jun 2017
                        • 18
                        • India
                        both are fine.. I get all the 12V outputs for a second and then turns off.
                        I dont understand 001:15E OVP in the schematic Page2. where does it come from?
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          You forced power board on with main board disconnected and voltages were temporary
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            The STB3.3V is connected to AC_DET so will be a maximum of 3.3V. When the opto-isolator PH6302 is switched on it should go to 0V.
                            • sat3182000
                              • Jun 2017
                              • 18
                              • India
                              Yes.. I have disconnected all other boards. Just working on Powersupply board.
                              I figured it out, I am looking for the reason why the PSU is shutting down main power once I connect a 1K resistor from STBY_3.3V to Power_ON
                              • sat3182000
                                • Jun 2017
                                • 18
                                • India
                                OK, This seems to be interesting.
                                PH6300 - PIN 1 and 2 = 1.09V - Turned on
                                PH6302 - PIN 1 and 2 = 1.05V - Turned on
                                PH6100 - PIN 1 and 2 = 8.7V - Blown out?
                                PH6201 - PIN 1 and 2 =0.96 V - Turned on
                                Looks like something is wrong with PH6100 - I was expecting around 1.2 to 1.4 but its 8.7V looks like it must have blown out.
                                • sat3182000
                                  • Jun 2017
                                  • 18
                                  • India
                                  Thank you!!! I notice that I did not thank you before
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    PH6100 Pins 1-2 should just have standard diode voltage as you mention for the others so I would also consider replacing it.
                                    • sat3182000
                                      • Jun 2017
                                      • 18
                                      • India
                                      I did replace the component, still the same voltage on pin 1 and 2
                                      I also noticed something, i do not see the link in the board from PIN 1 of 6100 to Pin 4 of IC6800. Am I reading it wrong?
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        What voltage do you have with the meter probes set to DC placed across Pins 1 & 2
                                        Only one of the administrators can change a Post Title or contents of a post.
                                        • pbig
                                          advices for repairing Sony Bravia 32EX600 after lightning strike
                                          by pbig
                                          hi everyone,
                                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                          - from connector CN6150 (15 poles)
                                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                          06-28-2023, 02:43 AM
                                        • Bardou Kari
                                          HP EliteBook 840 G6 – no power after lightning strike
                                          by Bardou Kari
                                          I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                          – Charger is OK and 19V is present at the motherboard.
                                          – No charging LED, no fan, no reaction.
                                          – I don’t see any 3.3V or 5V near the coils.
                                          – Battery is unplugged.
                                          – I’m new to board repair but can use a multimeter.
                                          I added a clear photo of the board.
                                          Any idea where to start or what to check next?
                                          Thanks a lot for your help!...
                                          07-01-2025, 10:45 AM
                                        • karthur
                                          Samsung UN60EH6000 wont come on after lightning strike.
                                          by karthur
                                          We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                          I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                          When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                          Here is what I have checked.
                                          On the power supply board, 14pin connector:
                                          1 :12.7 Vdc
                                          3 :12.7
                                          5 :12.7
                                          7 :12.7
                                          9 :0
                                          11 :5.
                                          13 :5....
                                          11-01-2023, 06:18 PM
                                        • MrCreosote
                                          Lightning Strike: 55" TV dead: is display panel OK?
                                          by MrCreosote
                                          THE LIGHTNING:
                                          This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                          Very close and probably a very strong EMP.
                                          THE TV:
                                          No standby LED. Some voltage from PSB (not totally dead).
                                          But found a kit of ALL 4 circuit boards for $55.
                                          At first thought, this will fix my TV.
                                          But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                          08-16-2021, 10:27 PM
                                        • pfl
                                          ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                                          by pfl
                                          Hello Everyone.
                                          This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                                          It consists in :
                                          • a power board were the full H bridge class D amplifier and main power rails are located
                                          • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                                          Power rails are ok.
                                          human interface is working fine
                                          Input levels are...
                                          01-23-2024, 10:21 AM
