4.7nf 100v instead of a 4nf 50V
  • thuss
    • Jul 2012
    • 321
    • uk
    Hi I have been advised to use a 4nf 50v ceramic capacitor- but I tried Rs components ebay etc.
    Can I use a 4.7nf 100v instead? It to replace a smd cap on a lg plasma buffer.
    (I like to take the advice I'm given by experienced forum users - but Im stuck at the moment earliest delivery from China is end of July).
    Thanks in advance
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: 4.7nf 100v instead of a 4nf 50V
    That depends on where in the circuit the cap fits......but I think using the 4.6nF 100V should not be a problem.
    • thuss
      • Jul 2012
      • 321
      • uk
      thanks for the info - its just that I like to stick to what I am advised
      • ten-d
        Nippon Chemi-con 100uf 100v BP electrolytic cap
        by ten-d
        Hi all!
        I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
        01-30-2024, 05:18 PM
      • spiros.p
        replace 100v 100nf ceramic capacitor with 50v 100nf
        by spiros.p
        can i replace 100v 100nf ceramic capacitor with 50v 100nf in an amplifier it will be safe?
        10-19-2021, 08:13 PM
      • Keshenatech1
        WS-WN523N2 WiFi AP Power Supply
        by Keshenatech1
        I had been using a WS-WN523N2 to generate WiFi from my wired ethernet internet connection. Recently it needed to be power cycled more and more frequently so I decided to open it up. I found 2 bulged 470uf 16V capacitors in the low voltage output side of the unit's power supply. The 2 other capacitors in the high voltage side, a 4.7uf 400V and a 22uf 100V both read low ESR so I decided to replace them as well. The 4.7uf 400V is directly across the output of the full wave bridge and the 22uf 100V is on the other side of an inductor coming off of the positive side of the bridge, negative side directly...
        02-16-2023, 01:33 PM
      • Fide
        PS5 WLOD EDM-030
        by Fide
        Hello guys,
        I try to repair a PS5 with a WLOD.
        At the beginning I should tell that I get a BLOD and after the UART reading and shorts on the caps near by the HDMI Encorder I change the IC. And after the change I get a WLOD. I also noticed that the filters was blown. I change them also.
        The caps near by the HDMI Encorder are not shorted now. I also change the HDMI Port.
        I get some readings in Diode Mode which doesnt look right to me.
        1. HDMI Pin 18 i get 0.100V and Pin 19 OL
        2. Diode on the back side 0,100V...
        05-12-2025, 02:17 PM
      • ianbak
        Dell Vostro 3578 Battery Error
        by ianbak
        Please can anyone shed some light on why my Dell Vostro 3578 is giving the following BIOS error: 'The primary battery is not identifiable and this system will not charge this battery pack.'?
        The problem is not the battery - I've tried three different identical ones, all Dell OEM. They all work perfectly in other systems (different models, though) whilst giving the same error in the Vostro.
        The laptop will run happily from the battery if it is charged and Windows accurately reports the charge level, proving that the communication between the laptop and the battery...
        10-17-2025, 02:52 AM
