replace 100v 100nf ceramic capacitor with 50v 100nf
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    can i replace 100v 100nf ceramic capacitor with 50v 100nf in an amplifier it will be safe?
    • 31294
    Re: ceramic
    that depends on the voltage being put into it.
    the 100v / 50v is the maximum the cap is designed to handle.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Re: ceramic
      The suitability question may be more than what DC voltage the part can withstand. Depending on the type of ceramic dielectric, specifically its temperature and voltage coefficients, the applied DC voltage may affect the part's capacitance. "COG" would be unaffected; "X7R" can be affected as much as 10% or 20%; "Y5V" or "Z5U" can be affected (reduced) by as much as ~80%.
      PeteS in CA
      • spiros.p
        • Dec 2020
        • 89
        • Greece
        Re: ceramic
        thanks for answers guys was very helpful.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
