Sony KDL-40LV5500
Power supply: A1660-720B
Mainboard : A1663-964B
T-Con: NP_HAC2LV1.1
Hello all, this TV has a normal sound and the backlight is working normally, but the screen is still blank black screen. Firstly i checked the T-Con Power which is good with 11.98V then i tested the T-Con self test method, disconnecting LVDS i connected 12V to the power pin and 3.3V to de pin 44 of the LVDS , at that time i could see plenty of vertical color lines on a black background same as a dead LCD panel, but not the expected color bars.
When checking the T-Con board i can see around the chip ISL24007IRZ a rainbow spot all around as i could imagine as a serious overheat of this chip.
I measured all necessary test points as following :
VDD: 3.37v
VCC_1.8: 1.82v
VCC_3.3: 3.37v
AVDD: 0v
AVDD_I: 12.1V
VIN: 11.98V
VDD10_33: 3.37v
VDDC_18: 1.81v
A picture of the T-CON from the net.
Thanks a lot for your help.
T-Con: NP_HAC2LV1.1
VDD: 3.37v
VCC_1.8: 1.82v
VCC_3.3: 3.37v
AVDD: 0v
AVDD_I: 12.1V
VIN: 11.98V
VDD10_33: 3.37v
VDDC_18: 1.81v
