LG 60PB6600 No Power
  • tvfixer007
    • Feb 2015
    • 86
    I got this TV from a lady she said it powers on and has audio but no picture. When I plugged it up I heard a sound from power supply and unplugged it quickly. I then removed the back cover and plugged it in again and seen that a ceramic capacitor was toasted on the power supply.
    I couldn't find any shorted components in that area where the fried cap is. Any idea if I should replace the cap and try it again, or could I be missing something?
  • tvfixer007
    • Feb 2015
    • 86
    Re: LG 60PB6600 No Power
    It's up and running. Just replaced that cap and crossed my fingers! lol
      It is the same value capacitance and Voltage as C608, it should be around 1000V rating or more, they are snubber cap for D602.
      • tvfixer007
        • Feb 2015
        • 86
        Correct. I wasn't exactly sure but assumed it was the same as C608. I found an old Y-SUS board from a 42" LG I never got around to and found a match. I got it back together and it's been on for an hour no issues so far.
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
