Issue with Samsung PS50c450 Plasma 50" no power up
  • edgimeno
    • Jun 2017
    • 15
    • Spain
    Hi there!!
    I just bought this TV yesterday, "as is". owner said "nothing happens when you hit the power button".
    Ok I got it home, connected to mains. Relays click back and forth 5 or 6 times, during 5-10 seconds, led blinks, and after that led stays on, relay stop and it wont respond to either remote or panel turn on command
    Opened it up
    Nothing seems burned, no bulged capacitors, nothing leaked (aparently).
    Checked Power supply: 5V stdby are there, nothing else (15v, 5v3 are off)
    Makes sense as the TV is "officially" off
    Force PS_ON to GND and nothing happens.
    Whenever I disconnect either the cables from X-main to Y-main, or the power supply to y-main, it powers up with the startup tune normally (no image as the Y-main is unplugged), but the from led reacts to the remote commands.
    Is this normal? Bad power supply? Bad Y-main? What else can I check? I checks Vs and I get (normal) 213V so maybe PS if OK
    Thanks in advance!
    So
  • edgimeno
    • Jun 2017
    • 15
    • Spain
    Re: Issue with Samsung PS50c450 Plasma 50" no power up
    Also If I unplug the Ymain from it's buffer board (slide it out of the 4 connectors), nothing changes (tv doesn't power on) when the Y main is powered. So this leads me to think that the issue is not in the buffer.
    So should I go and change the Y-main? It seems like a hard to troubleshoot board with lots of components on the bottom side too.
    Its model lj41-08458a
    15€ + 6€ shipping, not bad, I just don't want to waste the time it would take to get here if it's not that board
    Is it common for Y boards to get bad and lock the whole TV preventing it to power up? Is there anythign easy to diagnose on these boards?
    Thanks!!
    EDIT: I took one by one all the pins in the power to Y-sus plug, and the issue is the Vs lead. I insert one by one GND->Va->Vg and everything so far stays on, but as soon as I insert the Vs pin, I get a spark and it turns off, so there's got to be a large shortcut somewhere in the Y-sus board related to Vs , right?
    EDIT2: Sorry Im progressing on the board as I write here. Vs goes from power supply to Y-main, and then from Y-main to X-main. If I measure Vs normally I get 0ohm to GND, so I suspecting a shortcut in Y-main, but if I unplug X-main from Y-main, the shortcut is no longer there. Removed X-main from panel and I measure the shortvut between Vs and GND. It seems easy to diagnose now as it power only 2 sections, sets of mosfets in the powersink, and some other components. Gona isolate them all now
    • sordids999
      • May 2013
      • 2156
      PICTURES !!
      showing all the boards will hopefully help you more to fixing your problem
      • edgimeno
        • Jun 2017
        • 15
        • Spain
        Hold on...Im about to fix it LOL...traced the shortcut in X main isolating aread (good thing there are several jumpers to cut and resolder)
        I JUST desoldered the "offending" component. RJP30E2 mosfet...
        It has a clear shortcut among all 3 pins. Shortcut in the board is gone now.
        Goind to see what the quickest place to have it sent here
        Thanks!!
        • sordids999
          • May 2013
          • 2156
          opps second post was not showing when i posted
          • edgimeno
            • Jun 2017
            • 15
            • Spain
            No worries, I should probably delete this post as I found the issue quickly but I guess it may still be useful to someone else later
            Symptom: 50" plasma Samnsung TV not turning on. Relay clicks "on" them clicks back "off"
            Opened TV: Removed power cable from PS to Y-main. TV would start on (startup tune)
            Plug power to Y-main. Unplug Y-main to X-main. TV still starts up
            Remove all wires in X-main. Check between Vs and Gnd in X-main. Got 0 Ohm
            Removed X-main. Vs doesn't go to many components. Isolated one by one.
            Caps->Checked good
            Diode on heat sink->Checked good
            -IGBT mosfet on heatr sink. Had shortcut on all 3 pins. Replaced
            (Hopefully) this is it, will get back in 3 days (what takes the delivery of this component)
            • tw2005
              • Oct 2011
              • 6458
              Caps->Checked good
              I had more than one shorted plus a pair of 20Amp N FETs shorted too, threw in something temporary to test. First time it lasted 1 minute, then used a pair of Toshiba IGBTs with higher voltage and current rating. Lasted an hour.
              Board Heatsinks were very hot, suspect other components bad like driver ic, don't know as I usually don't try component on Samsung.
              Hope you have more luck, don't be surprised if it goes pop again.
              Also have a good look for cracked solders , I found on the fets one leg was completely cracked and floating.
              • edgimeno
                • Jun 2017
                • 15
                • Spain
                Will check that. Hopefully there's nothing bad beyond the IGBT, will know at the end of this week
                • edgimeno
                  • Jun 2017
                  • 15
                  • Spain
                  No dice...Unfortunately, I got the IGBT in my mail yesterday, soldered it, and...something strange happened.
                  Put it all back in place. Turned TV on. The relay clicked on and off, like when it was shorted. Tired to turn on again, Samsung tune played but screen was black. It all responded to remote commands (I mean the led flashed but screen was still black).
                  Checked the back side again and noticed 2 things:
                  -VS is gone. But in this case no matter what board I disconnect from the PS (Y sust, X sust), nothing changes
                  -This is worse, I get nothing at all (no startup flashes, nothign later) at the LOGIC board LED. It's just off all the time.
                  I remember this led used to flash at different rates when the Y-sust was shorted or when it was disconnected, but now, even if I unplug EVERY ribbon (except the one from the PS) in the logic board, nothing lights up in it
                  Did I fry it? Is is the PS now? How should I proceed to diagnose it without starting to just purchase boards randomly
                  BTW this LOGIC board is a LJ92-01705
                  • edgimeno
                    • Jun 2017
                    • 15
                    • Spain
                    Nobody? Should I try to manually short PS_ON to ground and/or VS_ON to Vcc? And see what happens? Thanks!
                    • edgimeno
                      • Jun 2017
                      • 15
                      • Spain
                      Bump...anyone? Thanks
                      • chrismurphy
                        • May 2014
                        • 251
                        • australia
                        Think you should give up ..I dont think you dont have enough knowledge to proceed in safe manner
                        Replacing boards randomly will cause you grief and will be costly
                        • edgimeno
                          • Jun 2017
                          • 15
                          • Spain
                          I dont know why youre saying that, I do have electronics knowledge but no experience on plasma TVs, thats why Im asking for help so I dont have to start swapping boards randomly. I already found a shortcut in my Ysus board and fixed it, but since then something else gave up and now I dont even have power in my logic board, I just need some directions on how to proceed to diagnose whats wrong
                          • maxvalutech
                            • 804
                            • australia
                            Do a search for Samsung Tech Talk issues around 2010/2011 .
                            • tw2005
                              • Oct 2011
                              • 6458
                              I'm a bit muddled with what you're saying. You probably need some cheat sheets or troubleshooting guides to help. Samsung expert I am not but I think this series if either x or y disconnected Vs will not stay on. You would have to have the probes on as you strat it and it may be there for a second but it will shut down straight away.
                              As for the logic board can you state what is connected and what is not?
                              Also you can kill the ymain sometimes with a bad X. I did that in the 42" version after trying to repair.
                              • edgimeno
                                • Jun 2017
                                • 15
                                • Spain
                                Thanks but in my cae, after repairing the X, I reassembled averything and realized that nothing worked, unplugged X and Y, and still don't get Vs and T-con seems to be completly off, my question is, how do I test if this is due to PS failure to power T-CON, o the T-CON itself?
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  So if power is disconnected from the x and y are the ribbon cables that go from the Logic Ctrl board ( you call it tcon) to x and Y disconnected? have you tried turning it on like that?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Have a look at this and see if this looks like your setup
                                    • edgimeno
                                      • Jun 2017
                                      • 15
                                      • Spain
                                      Yes, I totally isolated X and Y boards, removed EVERY wire from /to them (like f they were out of the chassis). Only PS, Main, and T-COn. I turn TV on, hear the Samsung chime (so at least SOMETHING in PS is alive and Main is alive), but I get no Vs, no Vg, no Va...Is T-COn dead? How can I test "whose fault this is"?
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Is the green activity light blinking on startup?
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
