le32c530f1
  • jonny78
    • Apr 2017
    • 72
    le32c530f1
    hi guys..picked up a le32c530f1 for free been testing this for sometime and everthing works great...picked up a remote for this set today and it just refuses to work...remote is an official samsung one and the right one for this model... and works fine but will not control the tv...all of the touch sensitive buttons work on the tv and the standby light works etc...ive took the back off the tv and found the part for it :
    http://www.ebay.co.uk/itm/BN96-13451...-/301969879082
    dont really want to be paying money out on this set..any advice as to why the tv wont allow me to control it with the remote?
    cheers
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: le32c530f1
    Bad ir sensor?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Re: le32c530f1
      Check that all the cables are connected especially the one from the IR board.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Re: le32c530f1
        How do you know if the remote you received is good or not??
        • jonny78
          • Apr 2017
          • 72
          Re: le32c530f1
          Originally posted by dskall
          Bad ir sensor?
          yep more than likely! would there be any fix wihout replacing the whole module.? the whole module is far to expensive and isnt worth it..like i said all of the pressure sensitive buttons work etc just wont work with the remote!
          • jonny78
            • Apr 2017
            • 72
            Re: le32c530f1
            hi..ive tested the remote on somebody elses tv which is the same model and it works fine!
            • jonny78
              • Apr 2017
              • 72
              Re: le32c530f1
              Done that still the same! i just dont want to replace the whole module because as you can see by the link on ebay its finacially not worth doing so!
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                Re: le32c530f1
                if you check the dc reading on the output of the ir sensor, you will see if it is sending a signal when it gets a command from the remote.
                you can change out the ir sensor with another from a scrapped set, but sometimes the pinout is different and you need to rearrange the legs a bit to get it to work.
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  Re: le32c530f1
                  The above ebay link says BN96-13451B = BN96-13022B = BN41-01382A Control panel Samsung Function Board
                  http://www.lcd-plasma-parts.co.uk/<b...XU-BUTTON-UNIT
                  £3.99 + VAT
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    Re: le32c530f1
                    £3.99 + VAT
                    dam, how could anyone turn a profit when you have to spend coin like that to get a tv up and running?
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Re: le32c530f1
                      Do you have the means to acquire the sensor??.....That'll be a lot less expensive......If you are getting signal then it may go to an IC that may not be economical to repair....Replace the sensor 1st if in doubt....
                      • jonny78
                        • Apr 2017
                        • 72
                        Re: le32c530f1
                        "The page you requested cannot be found"
                        • jonny78
                          • Apr 2017
                          • 72
                          Re: le32c530f1
                          £3.99 + VAT
                          Thanks..link doesnt work but found a few similar cheap ones but out of stock! ebay all want ridicolous amounts!!!
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            Re: le32c530f1
                            Just double checked the link but just noticed that they are out of stock which I hadn't noticed first time.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Re: le32c530f1
                              Probe your ir sensor pins while you press remote one should drop voltage. I would think most ir sensors out of different models will work.
                              • tmhobadcap
                                Pioneer VSX-522-K remote control not working???
                                by tmhobadcap
                                I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                12-24-2020, 01:44 AM
                              • piipo
                                Old Privileg 5.1 speakers remote control question
                                by piipo
                                Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                                09-18-2024, 01:55 AM
                              • hemant_2222
                                Schematic for Denon Remote Control RC1156
                                by hemant_2222
                                Hello Everyone,
                                Hope everyone is enjoying their repairs at hand!.
                                I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                                I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                                Please refer to the attached picture, i think the voltage divider is missing...
                                10-06-2023, 02:05 AM
                              • Babbar
                                1980s Holz Her 2420 belt sander - Only works when speed control at maximum
                                by Babbar
                                My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
                                11-13-2024, 01:54 AM
                              • dfear
                                hitachi 75hl16t64u - not responding to remote control
                                by dfear
                                I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                                It came in for a power issue which I have finally resolved by replacing the power supply.
                                The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                                Anyone have a clue how to fix TV?
                                FYI: I have checked the remote work s by pointing it at my camera on my phone....
                                09-02-2024, 12:15 PM
