Sony Bravia KDL-60EX645 FIXED, THANK YOU!
  • Static_Bracelet_Of_Love
    • May 2017
    • 4
    Thanks for the information on this forum!
    I was able to order a replacement board for this tv,
    the logic board 1-895-307-11 MBP,
    from PartServ
    (ShopJimmy was out of stock and low expectations of replenishment),
    replace the board,
    enter the service menu thru the secret key sequence,
    and take a guess at selecting the correct panel (which was extra difficult because the text on screen was so pixelated it was very hard to read.
    I used my smart phone to take photos, then edited the photo to increase clarity as much as I could, and when it restarted, the display was the proper orientation and clear text!
    total part cost $80
    time of research approx 2 hours
    time of repair approx 1 hour
    saved approx $1,000 if I had to buy a new tv at comparable size 60" and features
    thanks badcaps!
  • Diah
    • Feb 2013
    • 6435
    Re: Sony Bravia KDL-60EX645 FIXED, THANK YOU!
    good to hear you did it in this way.. there are other was called self diagnose by Sony, same to service menu hide No. but this will read the LCD ID and register it automatic in case logic board had different serial No-
      • May 2017
      • 4
      well last night the fixed tv would not turn on again, no power led lit at all, so I can't do any diagnostics.
      this part seems to be sold out all over the web, I wonder if that means this has a design defect and it fails after a certain number of hours in use?
      i'm requesting a refund under warranty, I'll see if I can find another board online, and I'll consider using a cpu fan to blow cool air on the heat sink of the replacement board because I noticed the old board was extremely hot during testing. that might mean i'll need to modify the back cover to drill some ventilation holes. lol, what a pain in the ass Sony!
      • Hamie
        • Apr 2014
        • 1383
        You've entered the service menu and played about with the settings. Pretty harsh wanting a refund.
          • May 2017
          • 4
          why do you say it's harsh? the part was sold with a warranty. why should i not exercise my right to a refund on a part that failed within the warranty period?
          • PopsCaps
            Sony Bravia KDL-40V2500 that will not power on
            by PopsCaps
            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
            I do not hear any sound and I cannot see any backlight.
            I have tried disconnecting every cable on each board one at a time to see if anything changes.
            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
            03-25-2025, 11:23 AM
          • justin35
            Sony bravia kdl-43w755c - boot loop
            by justin35
            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
            from what i read online it looks to be an emmc issue…
            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
            i took out the board and say an samsung 16gb emmc
            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
            i could try to put one instead of the 16gb one, but will it work?
            where do i get the software from?
            any help will be much appreciated!...
            03-06-2024, 12:26 PM
            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
            10-16-2024, 05:15 AM
          • Spc.
            Sony Bravia KD43XF7596BAEP - Android no picture
            by Spc.
            Greetings everyone.
            I also have Sony Bravia, model:
            Sony Bravia KD43XF7596BAEP - Android.
            What happend is that image dissapeared while we were watching tv.
            Diagnostics:
            1. TV turns on, no errors
            2. Backlight turs on, no errors
            3. Power indicator turns on, white color, no errors
            4. Menu works on android, you can hear sound while switching channels
            5. Volume up and down works via TV remote and via buttons
            6. Tunner works, HEVC / MPEG-4 decoder works
            7. I get audio from channels
            8. No picture is present,...
            05-19-2022, 04:28 AM
          • x_orange90_x
            Sony Bravia KD-50X690E NO SOUND
            by x_orange90_x
            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
            Has anyone else had this happen to their tv?
            10-05-2024, 05:01 AM
