A new hobby for me; Gathering Information
  • Yamiii
    • May 2017
    • 4
    Hello, My name is Travis. I've gotten an interest in repairing TV's and i can get a pretty good constant flow of "damaged" Tv's so i thought why not.
    I have a few questions that would be great to be answered by this knowledgeable forum.
    1) Can you guys point me in any direction to videos/guides to repairing TV's.
    2) Interchangeable parts for TV's and how many parts can be swapped out and replaced by other parts
    3) I've invested in a Multimeter any vids/tips on using it.
    I just want to feel more comfortable around a TV and to get a better understanding
    Would like to thank you guys for providing such great information and thanks for replying to someone who may seem a lost cause
  • vinceroger69
    • Mar 2012
    • 6714
    Re: A new hobby for me; Gathering Information
    For videos/guides i just use youtube there are some very good ones on tv repair also some very good ones regarding using a multi meter for boards that can be swapped out i use shopjimmy and see what they list as alternative boards that can be used in your tv but they have banned uk ip address so you need too use something like anonymox to view there web pages they also have some good pictures you can really zoom into so you can sometimes check parts/trace etc on the boards.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Once you get past the bulged caps videos. I would highly recommend norcal715 on youtube. Most important first step HOT side of power supply is most dangerous part of tv. Use care when making measurments. Also your ground point for measuring is different than the rest of the circuit. Also uk guys might want to know were you get your tv's
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Never understood that. Why exactly?
        Follow the white rabbit.
        • dskall
          • Oct 2016
          • 2905
          • usa
          A few posts from the guys in the UK say they have hard time picking up broken tv's
          • Yamiii
            • May 2017
            • 4
            That's completely fine , I try to be very careful when entering a TV i stay away from metals when plugged in and when testing i try to ground myself with the main metal on the board.
            • Ian Paul
              • Mar 2017
              • 23
              • United Kingdom
              Some decent text book advice when using a multimeter to check voltages:-
              Voltage measurement is perhaps the most common function a multimeter is used for. It is certainly the primary measurement taken for safety purposes , and it should be well understood by the operator of the meter. Being that voltage is always relative between two points, the meter must be firmly connected to two points in a circuit before it will provide a reliable measurement. That usually means both probes must be grasped by the user’s hands and held against the proper contact points of a voltage source or circuit while measuring.
              Because a hand-to-hand shock current path is the most dangerous, holding the meter probes on two points in a high-voltage circuit in this manner is always a potential hazard. If the protective insulation on the probes is worn or cracked, it is possible for the user’s fingers to come into contact with the probe conductors during the time of test, causing a bad shock to occur. If it is possible to use only one hand to grasp the probes, that is a safer option. Sometimes it is possible to “latch” one probe tip (onto the circuit test point so that it can be let go of and the other probe set in place, using only one hand. Special probe tip accessories such as spring clips can be attached to help facilitate this.
              • Yamiii
                • May 2017
                • 4
                Voltage measurement is perhaps the most common function a multimeter is used for. It is certainly the primary measurement taken for safety purposes , and it should be well understood by the operator of the meter. Being that voltage is always relative between two points, the meter must be firmly connected to two points in a circuit before it will provide a reliable measurement. That usually means both probes must be grasped by the user's hands and held against the proper contact points of a voltage source or circuit while measuring.
                Because a hand-to-hand shock current path is the most dangerous, holding the meter probes on two points in a high-voltage circuit in this manner is always a potential hazard. If the protective insulation on the probes is worn or cracked, it is possible for the user's fingers to come into contact with the probe conductors during the time of test, causing a bad shock to occur. If it is possible to use only one hand to grasp the probes, that is a safer option. Sometimes it is possible to “latch” one probe tip (onto the circuit test point so that it can be let go of and the other probe set in place, using only one hand. Special probe tip accessories such as spring clips can be attached to help facilitate this.
                Thanks for the info from now on i'll try to latch the negative to something rather than holding. Is there anywhere specific you can point me if not i'll continue to browse
                • Mark D
                  Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                  by Mark D
                  The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                  10-29-2024, 03:15 PM
                • 2elw
                  SVOD4 PCB pictures + parts
                  by 2elw
                  Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                  STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                  GW1N-UV9UG169C6/I5 FPGA - Its a...
                  07-04-2025, 12:23 PM
                • chaos-theory
                  RX580 MSI armor OC 8gb no post
                  by chaos-theory
                  I have a card that does post at all, the owner said it does go into windows but it gets stuck on the logo with artifacts, I have no idea if he is lying or not... I tried the card on my pc and it does not post at, no beeps, no bios nothing just all fans turning and nothing else. I tried plugging DVI or hdmi but nothing, I tried unplugging the 8 pin plug from the power supply and it's the same thing.
                  I just want it to post and get into the bios at least.
                  Forgive me if I am wrong, but I tested the 3 PCIe 12v power pins on the left(550ohm) and the 4th one from the right 3.3v (400ohm),...
                  04-18-2024, 02:42 AM
                • SurrealMustard
                  What parts can be salvaged from a plasma with a damaged display panel?
                  by SurrealMustard
                  I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                  03-09-2025, 08:29 PM
                • DynaxSC
                  Asus Rog Strix B360-I Gaming - Parts Identification
                  by DynaxSC
                  I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
                  I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
                  Thanks in advance...
                  08-23-2023, 07:56 AM
