Lg 50pk950 turns on by itself (stumped!)
Re: Lg 50pk950 turns on by itself (stumped!)
Update: Since covering the IR sensor, the TV has not turned on by itself in the 2 times I've left it plugged in for about an hour. Promising, but I'm hesitant to believe it! I uncovered the IR sensor and it turned itself on in the usual 15 minutes. On my 3rd test session now with IR covered. We'll see what happens. I'm trying to figure out how this makes sense because the IR sensor must not be bad or it would have caused my friend's TV to turn on by itself when it was in his. Do you guys think it could be giving false feedback to the main board by way of an intermittent wire in the harness from the SUB to the main board?Comment
Update: It's still turning on by itself with the IR covered.
Yes, I think something like a fluctuating voltage like that might be the issue, but would that have allowed this main board to work fine and not cause self power-up in my friend's TV? Maybe because it's a combination of issues or something to do with the cable in between the main board and the SUB board? I need to check each wire for continuity and test for fluctuating voltages when the TV is in standby.
Can anyone again suggest which voltages I should monitor and where would be the best to probe?Comment
I tried several times leaving it for hours with SUB board disconnected and it never came on, but I could try again while I'm waiting for something else to check. I would like to get a confirmation on what voltages to monitor and at which test point in the meantime.Comment
Also, I just checked for continuity on each wire of the cable between the main board and the SUB board and everything was okay, but of course it's possible that one of the wires could be intermittent; it's hard to move them around and test at the same time to see if something is intermittent in that way.Comment
I'm not seeing which pin, can you help me identify? I think my 2 pictures of the SUB board are good enough to show, right?ok, lets try something different.
locate the power on pin that goes to the main from the button and sub boards.
what does it read in stby. is the voltage fluctuating from the word go? then monitor that voltage till it powers up, annoying, but could prove interesting. it has to get its command from those boards, i can't see it being the main.Comment
Running out of ideas. If you have min/max meter you could monitor on/off pin to see if signal is originating. Does it have wifi? Have had strange things go on with wifi modules. When you unplug sub are you unplugging at main or sub?Last edited by dskall; 06-01-2017, 10:40 AM.I assume no responsibility for any stupid suggestions I might post.Comment
Also, I've noticed that if you touch certain areas of the SUB board (just handling it to cover and uncover the IR sensor with tape), the TV will turn on all by itself. I made sure it wasn't moving the cable going to it from the main board that was doing this and I also tried the other SUB board I have and it acts the same way. I think my body is just giving it the input it gets from the capacitance keypad (even though it is unplugged) near the traces for the ribbon cable plug for the keypad. What I'm wondering is if something is giving it this same false input and if there's some way to test this or isolate this.
Also, I found that my method of covering the IR sensor with masking tape was not sufficient to block IR beams; I tried a remote and it worked right through the masking tape. I could use a different type of tape or method, but I'm wondering if the IR problem theory is not necessary to explore? Ideas? Anyone? Thanks in advance!Comment
My Fluke does have min/max, but which pin is the on/off one? I'm not sure what it would be marked; how can I identify it?Comment
There are 9 test points on the back of the board, would one of these be the on/off point you are referring to? They are:
IR
KEY 1
KEY 2
LED-RED
SCL
SDA
3.3VST
GND
3.3V
(See my pictures in post #2)Comment
Your on/off key presses should change voltages on one of the wires. Is there any missing shielding or grounding. Still wonder if mainboard doesn't factor in to this somehowI assume no responsibility for any stupid suggestions I might post.Comment
You also have an scl and sda which are multiplex. What they are interfacing with I don't know. As I am reaching limits of my skillset here I hope someone with more knowledge will contribute.I assume no responsibility for any stupid suggestions I might post.Comment
I am wondering if the IR module is having issues because you say that if you cover it dose not turn on by it self
Just a thoughtComment
A long shot but have you checked to see if there is any AC (or high frequency smps) ripple on any of the DC lines. This could be due to a leaky diode(s) or duff capacitor(s) and could be the cause of the problem you have.Last edited by dick_barton; 06-01-2017, 11:33 AM.Willing to help but I'm no expert.Comment
Thank you, but I posted an update after that that it WAS still turning on by itself, it just didn't the first few tries. Also, I later found that the masking tape I was using wasn't blocking a remote signal, so I might retry the tests with a better cover, but will pursue the other tests first.Comment
Thanks for chiming in! No, I have not checked for that. Any suggestion on exactly where to start? Just put my meter to AC and see what is on the VS, VA, Stby, etc.? Or something else?Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
