Samsung LE27T51BX/BWT no start
  • rafis
    • May 2017
    • 22
    • Russia
    Re: Samsung LE27T51BX/BWT no start
    Smd fuses require second tip, that I don't have. Instead removed caps and checked fuses again, all open (caps were parallel to fuse). Fuse order cost is approx. same as board, so will order a board
    • vinceroger69
      • Mar 2012
      • 6714
      If you have two soldering irons you can remove them quickly but yes a replacement board was probably the best bet if other parts have blown too.
      • rafis
        • May 2017
        • 22
        • Russia
        Will desolder and check them later just to confirm. Have to find second solderer in garage
        • dskall
          • Oct 2016
          • 2905
          • usa
          You can at least lift one end with single soldering iron alternately heating one end then the other and maybe adding some leaded solder
          • rafis
            • May 2017
            • 22
            • Russia
            Replaced inventer. Unit is starting up, but I got bad picture. Please see screen attached
            • rafis
              • May 2017
              • 22
              • Russia
              #26
              Blue screen and menu are perfectly fine. Input at the picture is from PC D-SUB
              • rafis
                • May 2017
                • 22
                • Russia
                #27
                Pictures from AV IN and menu
