58l1350uc no power/lights
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: 58l1350uc no power/lights
    Looking at the link you provided in the first post, BudM suggests in that post that if you have PW_On and 5V standby then to check C113. Best if you can remove it and test the capacitance is correct.
    He also suggests to start troubleshooting around U1 (SSC9522S) by checking the voltage between Pin 4 (GND) and Pin 14 (VCC) of that IC. Unfortunately without the schematic the problem was never resolved but it would be worth doing the checks just mentioned.
    • tmlfan
      • Jun 2011
      • 109
      changed out final resistor to what i assume is 274 stamped on it, swapped with a 270k resistor also pulled c113 out and the capacitance is supposed to be 27n and measured at 26, still nothing, might be easier at this point to admint defeat and either chuck it or buy a new power board, but i have looked and parts for this tv are either hard to find or more than i want to spend to fix it
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Hold fire if you can. Perhaps Budm will see this post and offer some advice.
        • dskall
          • Oct 2016
          • 2905
          • usa
          So what is voltage on main cap now?
          • tmlfan
            • Jun 2011
            • 109
            hasn't changed any, now i've been pulling out caps and testing them from the top of the board and so far they have all been testing out but the 2 main ones are rated at 82u and are measuring at 71u, is there a 20% tolerance on most caps?
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              See my disclaimer. Your pfc is low and I think the ic801 is for your standby voltage not your boosted voltage. Pictures and info is scattered between two posts so confusing for me. If you could post some clear pictures of your power board front and back and ic numbers from back of board would help.
              • tmlfan
                • Jun 2011
                • 109
                #27
                How are these ?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  What is number on u3?
                  • tmlfan
                    • Jun 2011
                    • 109
                    #29
                    1607b
                    pfxj
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      #30
                      There's a couple resistors on pin 1 of u3 that make a voltage divider to set your pfc voltage you need to check
                      • tmlfan
                        • Jun 2011
                        • 109
                        #31
                        i have been trying to find a pinout for this chip so i can determine what pin is ground so i can use that to figure out what pin is pin 1 because there's no indent on ic to label pin 1 but the funny thing is when i set my meter to test continuity it beeps if there's a connection and when i ground my black probe on the board the red probe doesn't beep on any of the 8 pins on u3
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          #32
                          On picture of your board looks like there is a 1 lower left and 5 upper right printed on board
                          https://cdn.badcaps-static.com/pdfs/...1c0971084b.pdf
                          • tmlfan
                            • Jun 2011
                            • 109
                            #33
                            Checked r20 and r21, both 1M resistors and both measure 0.846M ohms
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              #34
                              I would replace them and check you voltage again on main cap
                              • tmlfan
                                • Jun 2011
                                • 109
                                #35
                                169V on both caps and 169V dc across power transistor
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  #36
                                  When measuring the Vdc on the main caps, are you placing the black lead on the -ve and the red lead on the +ve of the caps??
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    #37
                                    That must be in standby because you had 360v before
                                    • tmlfan
                                      • Jun 2011
                                      • 109
                                      #38
                                      yeah i dont know what happened, voltage dropped once i put both of those 1M resistors on pin 1 of u3 (R20/R21)
                                      • tmlfan
                                        • Jun 2011
                                        • 109
                                        #39
                                        yes to black lead on - and red on +
                                        • Mouse2222
                                          • Nov 2017
                                          I have a 58L1350UC toshiba tv that has no power and I have 0 volts at the 5vpin. Any ideas would be great. I am new to this site
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • JDC
                                            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                            by JDC
                                            ONN 100012588
                                            Issue: No Power, Then Rebooting After Main Board Change
                                            Short answer: replace main board and power board
                                            Technical answer: replace main board and Q306 & Q307 on power board.
                                            Long answer:
                                            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                            07-15-2022, 07:39 AM
