58l1350uc no power/lights
  • tmlfan
    • Jun 2011
    • 109
    so i was given a toshiba 58l1350uc tv that doesn't work, when i plug it in there is no lights or anything on the front panel, i have been following the other thread located here https://www.badcaps.net/forum/showth...403#post615403
    i have taken the back off of the tv and started to take measurements, plugged in i get 5v output off of the main board but not 12v
    pwon = 3v
    power mosfets c101a/c101b = 360V on both
    i don't see any leaking/bulging capacitors but havent taken any of them out to test yet and the fuse thats in the main power board tested good also
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: 58l1350uc no power/lights
    Are c101a/c101b your main caps= 360V on both. You don't list a country. What voltage are you?
    • tmlfan
      • Jun 2011
      • 109
      sorry yes, c101a and c101b are the main caps and i am getting 360vdc on bith which is what i am suposed to and i am located in canada
      • dskall
        • Oct 2016
        • 2905
        • usa
        360v seems low. Think you should be getting 390v
        • dskall
          • Oct 2016
          • 2905
          • usa
          Need good clear straight on pictures of back of tv with cover off and each board.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            As Dskall says that voltage is to low and is given as 390V in the thread you refer to.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              With your meter set to DC volts what voltage do you have when you connect the black probe to Pin5 and red probe to Pin3 of U801.
              Do not let the probes slip.
              Edit
              Some good photo's of your power supply board would be useful.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Originally posted by dick_barton
                with your meter set to dc volts what voltage do you have when you connect the black probe to pin5 and red probe to pin3 of u801.
                Edit
                some good photo's of your power supply board would be useful.
                +10
                • tmlfan
                  • Jun 2011
                  • 109
                  Let me know if these are good enough
                  • tmlfan
                    • Jun 2011
                    • 109
                    black probe to pin 5 and red pin to probe 3 i get -17.5 volts
                    also getting 153 Vdc across power transistor BD1 when plugged in
                    with main board unplugged i get 170Vdc across power transistor/170Vdc across c101a and c101b and -15.8 on pin 3/5 of u801
                    • tmlfan
                      • Jun 2011
                      • 109
                      another thing to note is when i take Vdc readings across pins 1/2/3 from this pic here from previous thread on my board i get voltage readings of 0/0/16.5 but that is with power board only plugged into wall and no other boards, dont know if that matters or not...pic is from previous thread
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        170v in standby is good 350v is low but pfc is working. I would check feedback resistors on boost controller for low resistance. Others correct me if i'm wrong
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Ooops sorry but I got the probe connections the wrong way round in the photo so just need to reverse the voltage reading to +15.8V
                          The STR-A6069H has a maximum operating voltage of 16.8V so the voltage seems to be correct as per post #10
                          It looks as though the PFC circuit is working (360V) but it's not bringing the supply voltage across those capacitors C1A/C1B fully up to 390V.
                          With the set powered off and unplugged from the wall socket I would check the resistance of R801, R802, R803, R808 & R701 and ensure they match what their supposed value.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Is u801 for standby or pfc control
                            • tmlfan
                              • Jun 2011
                              • 109
                              r801 = 1.31M ohms
                              r802 =2.17M ohms
                              r803 =145 ohms
                              r808 =4.87k ohms
                              r701 =1.00M ohms
                              if i read resistors right then this is what values are supposed to be
                              r801 = 2.2M
                              r802 = 2.2M
                              r803 = cant really make it out, looks like 274 wrote on it with a line under the 4
                              r808 = 2.2M
                              r701 = 1.0M
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                You can replace bad with 1/4w regular resistors
                                • tmlfan
                                  • Jun 2011
                                  • 109
                                  any idea about r803
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    My thoughts here are that when reading other threads where the PFC voltage was not quite up to what it should be, it often came down to the fact that one or more of the resistors in the resistor chain was out of tolerance. Replacing them brought the supply back to it's normal working value.
                                    In the attached photo it would be the resistor chain feeding the BR pin of the IC
                                    • tmlfan
                                      • Jun 2011
                                      • 109
                                      i changed r801/r808, no change in voltages, any idea what value r803 should be, its smaller than the rest and like i said it looks like it has 274 wrote on it with a line under the 4 and is only reading 4.87k ohms....unless it is supposed to be 472 which would make it 4700 which would make sense
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        There is a capacitor C808 in parallel with R803 that I would check. The problem is without a schematic I don't know what the value should be.
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
