Vizio SV471XVT No Standby, Dead Set
  • fharris1977
    • May 2017
    • 132
    Hello. I got a vizio i'm trying to repair and I'm pretty sure it's the power supply because of no standby. The fuse is open and i was wondering if I could replace it with a fuse with the same specs but different size. I ordered 10 mm instead of 20 mm. Also, if anyone has repaired this board before, I'd appreciate their help, because the board costs about 100 bucks. Thanks.
    Re: Vizio SV471XVT No Standby, Dead Set
    We cannot tell what you have exactly. Where are the pictures?
    There are more than one version of this TV.
    https://www.badcaps.net/forum/showthread.php?t=39740
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      If the fuse has blown I would investigate why and not just replace it. If there's a fault then it would just blow again and could cause more damage.
      Replace the fuse with an identical fuse, length and current rating and don't bodge it.
      • fharris1977
        • May 2017
        • 132
        I think the fuse actually blew when I tested the bridge rectifier for the 160 volts dc. I got 120 volts ac input when I tested it, but heard a spark when I tried to test the 160 volts output. But I have to order the correct size fuse due to limited parts in mississippi. Here are pics of the power supply and the wrong sized fuse but same specs.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          So it's not a clip in fuse as I thought so you should be OK to use as a replacement. I would be tempted to add some insulated sleeving on the exposed leads and then solder it in.
          How about some photo's of the full power supply
          • vinceroger69
            • Mar 2012
            • 6714
            i would also re test the bridge rectifier just incase thats gone short circuit before you replace the fuse
              So that smaller body fuse has the same Voltage rating as the original fuse?
              • fharris1977
                • May 2017
                • 132
                Yep. It's 6.3 amp 250v
                • fharris1977
                  • May 2017
                  • 132
                  Here are more pics of the power supply and the inside and outside of the tv itself.
                    Can you please provide the straight shot pictures of the bottom side of the board.
                    Too bad the large heatsink cannot be easily removed to see the parts under the heatsink.
                    I would check the resistance between the two outer pins of the bridge to see if it shows low resistance (bad) reading that can cause the fuse to blow or not, also the power devices mounted on the heatstink should also be checked for low resistance (bad).
                    http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
                    Vizio 0500-0407-0800 (DPS-303AP A) Power Supply for SV471XVT
                    • Ian Paul
                      • Mar 2017
                      • 23
                      • United Kingdom
                      Is your replacement Time-lag fuse, denoted with a T?
                      • fharris1977
                        • May 2017
                        • 132
                        This is how the fuse was listed on ebay I bought. 6.3A 250v Fuses CERAMIC, Fast Blow, F6.3A, 6.3 amp 6.3A, 3.6X10mm. Does it sound like the right one. I didn't know whether to get the fast blow or slow blow ones.
                          If you at the label for the fuse rating as printed on the circuit board then you can tell if it is Time delays or Fast-blo.
                          Does it show as T6.3 250V, T= Time-Delayed which is more likely yo be used on your board.
                          That little fuse is blocking the print so I cannot see what is printed on the board.
                          • fharris1977
                            • May 2017
                            • 132
                            Yeah its a T. I got the wrong one. Feel kinda stupid now.
                            • Ian Paul
                              • Mar 2017
                              • 23
                              • United Kingdom
                              This fuse should be available from Mouser/Digikey: BK-S505H-V-6.3-R
                              • fharris1977
                                • May 2017
                                • 132
                                I hate to sound stupid but when checking these components, is it best to desolder them and take them out of circuit for best results. I know capacitors do for sure, but what about mosfets and rectifiers and diodes, etc.
                                  You can do resistance test to look for shorts or low resistance on the those components I suggested, and when the reading looks suspicious then you remove it from the board and test it again off the board.
                                  • fharris1977
                                    Vizio D50u-D1 Dead Set No Standby
                                    by fharris1977
                                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                    12-28-2023, 10:25 AM
                                  • piposarcade
                                    Samsung UN50KU6300 dead no standby led
                                    by piposarcade
                                    01-04-2024, 01:33 PM
                                    Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                    05-22-2024, 02:07 PM
                                  • jacobtc
                                    LG C1 65'' dead standby
                                    by jacobtc
                                    I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                                    If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                                    If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                                    I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                                    01-29-2025, 04:27 AM
                                  • piposarcade
                                    by piposarcade
                                    Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                    01-04-2024, 12:03 PM
                                  • dellxps15
                                    macbook a1707 15 inch trackpad dead. blown fuse identification
                                    by dellxps15
                                    hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                    another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                    04-30-2024, 10:48 AM
