SONY KDL46Z4100 Dim image
  • ishler
    • May 2017
    • 4
    The display on this TV looks like it's suffering from either low back light or brightness. With both controls set to max the image is dark and biased to the red. I've read the several threads on this model and although i initially suspected the backlight I can't rule out the T-con but I'm not seeing any of the artifacts shown in the photos other than the dark image. Since the backlight is integrated in the panel i was thinking of replacing the backlight driver board. I also have the equipment to change out the AS15 on the T-con if needed but thought I would ask if there were any other ideas before I start down that road?
    Thanks in advance for any help
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: SONY KDL46Z4100 Dim image
    A picture is worth a thousand words
    • ishler
      • May 2017
      • 4
      On my list of todo's. I need some help to take it down stairs into my shop. Hopefully in a day or two. Getting old is a PITA!
      • dskall
        • Oct 2016
        • 2905
        • usa
        Can you take some pictures of screen?
        • ishler
          • May 2017
          • 4
          Here is a picture, I wish it was more representative of what I'm seeing. The actual picture is darker with a dark shading around the borders. The backlight,brightness and picture controls are at maximum. When you back off the controls the image is redder.
          • rimwall
            Sony KD-65x7500D - double image - Tcon or Panel?
            by rimwall
            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
            Today, 02:09 AM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • iglitare
            by iglitare
            09-04-2025, 07:13 AM
          • bbrain
            Sony KD-55AG9 TCON?
            by bbrain
            I have this problem with my Sony 55' AG9.
            It flashes 4x.
            I have found the service manual, and seems it is the TCON.
            Before I buy a TCON can someone check the vid?
            Thanks in advance!...
            09-19-2024, 10:50 AM
          • jason123
            ASUS PG27V Rolling Image - TCON?
            by jason123
            Hi there,
            My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
            I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
            It does this even with the monitor not connected to a computer / graphics card....
            11-01-2025, 05:41 PM
