Sony KDL-32S5600 stuck in stb by /relay click/
  • coojoe_213
    • Nov 2015
    • 105
    • bulgaria
    Hi everyone. My old lcd tv stuck in stand by mode. No picture, no sound, no backlight, no blinking /stay red led/
    1. When i put in AC i hear click from relay
    2. Every 25 sec relay click
    3. No blinking led std by
    Voltage on PS: 3.3v-3.3v, 12V-12.4V, 13V-16.4V???
    I check all diodes is perfect, all capacitors with esr meter ...perfect.
    Here is a service manual:
    I love this tv i hope some help to repair it :/
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KDL-32S5600 stuck in stb by /relay click/
    Need good clear straight on pictures of back of tv with cover off and each board.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Disconnect the PSU from the Main Bd and see if it still clicks.
      • coojoe_213
        • Nov 2015
        • 105
        • bulgaria
        I disconnect PS from Main Board, and relay doesn't click now.
        I think my problem is Eeprom/SPIFlash.
        I need a 25p10vp SPI Flash, 24c64 Eeprom software. Can you upload files somewhere. Thanks.
        • coojoe_213
          • Nov 2015
          • 105
          • bulgaria
          I found flash and eeprom software but the situation is the same.
          I write in first post, i have 16.4v on on pins with 13v is this normal or no?
          May be the nand chip is my problem.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Would you like to share the files for others who may have a problem with this set.
            https://www.badcaps.net/forum/showthread.php?t=59877
            Have you read through the following thread
            https://www.badcaps.net/forum/showth...hlight=32S5600
            • coojoe_213
              • Nov 2015
              • 105
              • bulgaria
              TV now work. The problem was nand flash. I upload all perfect files on your link. If you can please edit topic to''solved''. Thanks.
              • aniello68
                • Oct 2013
                • 4
                • italia
                Hello friend what have dump file nand for sony dkl 32s5600
                • anatolijus57
                  • May 2023
                  • литва
                  здравствуйте.Прошу поделиться прошивкой nanl-flash для телевизора sony -kdl32s5600.спасибо,Анатолий.
                  • lotas
                    • Jan 2016
                    • 4664
                    • Russia
                    https://www.youtube.com/watch?v=-i4P1jmRIkM
                    • anatolijus57
                      • May 2023
                      • литва
                      спасибо за прошивку ,помогло.
                      • realbuddy
                        • May 2024
                        • Spain
                        Анатолий приветствую!
                        похоже у меня такая же проблема с телевизором, но пока не понял как её решить
                        пишут что нужно перепаять NAND память, и вроде как даже продают их для этой модели но не понятно прошиты ли они, а программатора у меня нет.
                        а в этой инструкции вообще даже крышку не снимают судя по всему
                        http://download.portalmrelectronico....tbloqueado.pdf
                        как я понял у вас была похожая проблема и вы её решили.
                        Спасибо!​
                        • bogosort
                          Sony DVD player stuck tray (DVP-SR310P)
                          by bogosort
                          I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                          Anyone knows why?
                          Thank you....
                          05-11-2024, 04:29 PM
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
                        • dkneyle
                          Sony KDL-46HX850 Can't upgrade/update firmware
                          by dkneyle
                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                          09-25-2024, 10:44 PM
                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 05:27 AM
                        • jm1234
                          9V relay temperature 40C
                          by jm1234
                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                          05-09-2024, 03:03 AM
