Philips 32PFL3008H/12 repair, blown PSU, Vestel 17IPS19-5P, SMD resistors
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This 32" LED Vestel has blown 3.15A fuse, two RL207 diodes from rectifier bridge, switching regulator Infineon ICE3BR0665J (IC303), a zener diode (D314, SOD-123, marking "WE", possibly 9.1V zener), and burnt SMD R301, R302, R303 & R304 in parallel. R302-R304 are 2.7Ω (from marking), but R301 is unreadable. I could guess that all four are the same, but the remnants of R301 marking make me think this one could be different. Perhaps 3.3Ω? These resistors are connected to Current Sense pin of IC303.
    I've searched schematics of 17IPS19-5P and there're slight differences with mine. Resistors are all 2.2Ω and IC303 is ICE3BR1765J instead. Not surprising, since "17IPS19-5P" is PCB name, not actual PSU code. Different components can be fitted in same PCB producing different circuits for smaller or larger backlights. I think that PSU code is 23095011 (from a paper label) and Philips code is 9965-900-05964.
    Anyone have a board like this and can confirm these resistors, please? Or, is it that important if it's 2.7Ω or 3.3Ω? They're in parallel, so we're talking about an equivalent of 0.68Ω or 0.72Ω.
    Re: Philips 32PFL3008H/12 repair, blown PSU, Vestel 17IPS19-5P, SMD resistors
    The CS resistance will determine what the current will be to trip the protection.
    I.E. lets say that you want the protection to kick in when the current through the resistor is 1A, so if we use 1 Ohm so at 1A you will have 1Vdrops to trip the circuit, but if you replace the resistor with 0.50 Ohms then the circuit will not trip until the current through the resistor is at 2A.
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      Thanks. I’ve put a 0.68Ω axial resistor and it’s working fine (replacing all other components, of course). If that resistor determines current limit for switching regulator, then I think that 0.04Ω tolerance won’t be a critical deviation.
      • TinkerTron
        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
        by TinkerTron
        Hey everyone,
        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
        Instead, here's what's been bugging me so far:
        The schematic...
        03-06-2025, 02:03 PM
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • Yrouel
        Philips 22PFL2908H/12 - Vestel 17MB62-1 - Possible to enable HDMI CEC?
        by Yrouel
        I have this tv for which I'd like to enable HDMI CEC (EasyLink as Philips calls it) if possible.
        The CPU/SoC should support it and I found about the possibility of customizing the TV behavior/functionality with the hardware and software profiles.
        I also got serial access to the TV through the SCART connector (side note how do you dump the firmware through that port?)
        I'm attaching everything I got about this TV: A zipped folder with various material like the profiles, a log of the boot process, a picture of the service menu, etc.; the service manual...
        05-23-2021, 06:59 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
