My LG monitor has been recapped about 2 or 3 years ago with ordinary caps (not low ESR) But they seem OK from what I can gather measuring them in circuit? I have been getting horizontal colors at startup (Rarely) and sometimes flickering black and white vertical stripes about 4 to 5 inches across at startup. This time though after installing AMD Catalyst drivers the day before it started up and went to a whitescreen with no signal. I thought it was the AMD Catalyst drivers but I tried another monitor and it worked OK. Ive taken the LG apart but cant find anything wrong yet except for 2 transistors that dont measure up on the diode test,( KJE W9 ) Im assuming theyre transistors? The ribbon cable to the T-Con is OK. I cant find a service manual or schematic for this model. Any ideas/suggestions appreciated. Sorry about there being no photos, Ive lost the battery charger for my camera and have it on order.
LG Flatron W2242P-BF Monitor Whitescreen.
HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Tags: None -
Re: LG Flatron W2242P-BF Monitor Whitescreen.
Ive found those ""transistors"" on the T-Con board (KJE W9) were actually diodes so they are OK,I cant find anything obviously wrong with the T-Con board so Im starting to think its maybe the electrolytic caps I installed about 3 years ago because they werent low ESR types. Would bad electro caps cause T-Con type faults like flickering 5 inch wide black and white vertical stripes. Like a test pattern?HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S. -
Bump, Yoo Hoo! Anyone home? Ive cleaned the ribbon cable display plug on both ends with DeoXit. Now, without it being connected to the computer the monitor goes to white screen at start, then goes to black screen, it does this a few times then stays off? Will bad capacitors cause whitescreen?HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.Comment
Are you sure you re-connected the ribbon cables you cleaned properly/correctly??Comment
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by keepreadHi there!
Someone gave me their old monitor, it's Dell S2715ht.
The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs... -
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
- Loading...
