Sharp LC-60EQ10U Scrolling Horizontal Lines
  • scott00
    • Apr 2017
    • 10
    • US
    I am having scrolling horizontal lines across my 60" Sharp TV LC-60EQ10U. I have already replaced the t-conn board with no difference. I then ran across this forum and started doing some diagnostics. Looking at the rear of the TV I removed the left 2 ribbon cables off the t-conn board, there are 4 ribbon cables total. No scrolling and the left half looks great, just a little dark and the right side just white.
    Then looking at the rear of the TV I removed the right 2 ribbon cable and the right side screen is scrolling lines and very dark. The left is white and some scrolling.
    I read other posts stating that there is a tab driver board I should remove?? I am assuming on the right side as I am looking at the front of the TV. How and where do I find this board. Will this work on my TV and how do I accomplish this task. I am a newbie so be kind and any help is appreciated.
    Thanks,
    Scott
  • scott00
    • Apr 2017
    • 10
    • US
    Re: Sharp LC-60EQ10U Scrolling Horizontal Lines
    I have read other posts that state this TV does not have the tab driver boards. Is this true? If it does, how do I remove?
    • budwich
      • Jul 2015
      • 3097
      it does. It doesn't have side edge boards as the tab drivers cables are connected to the bottom edge boards directly. Trace / look on the side of the panel and follow the flex cables down to the bottom corner of the panel. In terms of "tab problems" with the 60/70 sets, it isn't the edge boards that are usually the issue, it is the tabs themselves.
      • scott00
        • Apr 2017
        • 10
        • US
        Thanks for the info. So I could just remove the single connector at the bottom or remove all tabs on the right side?? Sorry for the newbie questions. I will work on this TV this weekend.
        • budwich
          • Jul 2015
          • 3097
          I wouldn't go that fast on anything ESPECIALLY since removing the WRONG thing is "fatal" for the set. Do some readings around the area. Do some more tests.... the tabs flex cables proceed toward the bottom of the panel on both side and are usually connected to some form of "clampable" connector that can be unclamped / clamped to disconnect that section. Try doing this at both sides (one at a time) and look at the resulting display. That will provide you with more understanding about what's happening with your set.
          further... from your picture post, it appears that one of the cables is not clamped properly. use your glasses when working with this things... :-)
          • scott00
            • Apr 2017
            • 10
            • US
            OK, I have finally had time to do more investigation. I have removed the trim from the sides and bottom of the TV.
            To recap, I removed the 2 cables from the left of the tconn board (looking at the back) and the left of the TV (looking at the front) looks great. So it looks like the right side tabs have issues.
            It looks like the lower right tab is burnt.
            I see the side tabs are connected to boards along the bottom of the TV. There are 2 on the left and 2 on the right. How do I proceed from here? Can I just remove 1 of the clamp-able connectors, or do I remove both?
            Thanks for all the help!!
            • budwich
              • Jul 2015
              • 3097
              I can't tell from your picture orientation (last one). Is the "burnt driver" on the side of the set or at the bottom. Your set can only be saved IF the driver is on the side and not the bottom. You have to remove both side tabs on the side that is bad.
              • scott00
                • Apr 2017
                • 10
                • US
                The burnt driver is on the side. So I remove both clamp-able cables from the bottom left (looking at the back)? I can't do anything to the side of the TV, right? On my 60 it is all along the bottom.
                • budwich
                  • Jul 2015
                  • 3097
                  The "clamp downs" are used only for "testing / investigating" which side is bad. The actual "save" is done by "tearing away" the bad side drivers / tab from the panel.
                  Hopefully we are talking the same language... :-) I am not sure at this moment exactly what you are referring to.... maybe edit your picture and add an "arrow or two" to point out exactly what you are referring to.
                  Further on your last picture, there appears to be 3 tabs on the side.
                  • scott00
                    • Apr 2017
                    • 10
                    • US
                    OK, I did that test with disconnecting from the tconn board. I disconnected the left 2 connectors (from the back) to show it is the right side (from the front) tabs are bad. I was getting confused since the 60 does not have side tab boards. So now that I proved it is the right side (from the front) I just tear or cut from the panel all 3 tabs or just the burned out looking tab?
                    • scott00
                      • Apr 2017
                      • 10
                      • US
                      There were actually 5 tabs. Just peeled off the tabs and 'She is Alive'!! TV seems to work great.
                      Thanks For all your help and patience with a newbie!!
                      • budwich
                        • Jul 2015
                        • 3097
                        great... happy viewing.
                        • j3st3r12
                          • Sep 2017
                          • 3
                          Thanks to everyone on this site I have saved my LC-60EQ10U! If you are looking at the front of the screen, I tore off the right side tabs(could be different for everyone). I figured this out by disconnecting each T-Con connector, which is centered at the bottom on the back of the TV(there are 4 connectors), and turning the TV on to check the picture each time a new cable was removed(3 will always be plugged in when checking). When I removed the far left T-Con connector(looking at the back of the TV), the left side of the screen(looking at the front of the TV) looked perfect and the right side(looking at the front on the TV) was completely white with vertical RGB colored lines. I decided that the right side(looking at the TV) was the one with the problem. I then removed the driver tabs on the same side of the TV that the T-Con cable was disconnected. So since my far left T-Con cable was disconnected(looking at the back of the TV), I removed the right side tabs(looking at the front of the tv), and while the TV was on, I tore each tab off cleanly with a pair of needle nose pliers watching the TV become clearer as I continued to rip all 5 tabs off. Once the 5 tabs are completely off; Unplug TV, plug all T-Con connectors back in so that all 4 connectors are connected, plug the TV back in and boom!
                          Thank you again Badcaps!!
                          • tibornagy
                            • Feb 2018
                            • usa
                            i think i may have jumped the gun here, i followed these instructions and removed all the tabs on my left side...there was 8 on each side and i removed all 8 on the left bottom side..crap
                            • budwich
                              • Jul 2015
                              • 3097
                              :-( you can't remove the tabs that are along the BOTTOM. "SIDE" means side of the set. Good learning experience though :-)
                              • juliusvichinsky
                                • Aug 2018
                                • 5
                                Followed the guidance and it worked perfectly. Truly amazing. Thank you
                                • boydsc
                                  • Jul 2018
                                  • 10
                                  • US
                                  Question , what are those tabs there for if removing them fixes a bad picture and the tv works fine without them ? What is their function ?
                                  • bbair
                                    • Dec 2018
                                    I can't believe it, I followed the directions in this thread, and my LC-60EQ10U works like new! I removed the 5 tabs from the left side (facing the screen) and it is back to normal! Any bets on how long this will last? I've never ripped anything off of a LCD panel and made it work better, that's for sure.
                                    • jaco2d
                                      Sharp 50bj2ke horizontal lines
                                      by jaco2d
                                      This is only my seond post and so far i am very impressed with the forums.
                                      I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                                      The small white box thing in the pics is not the tv its a reflection from the window
                                      Any suggestions...
                                      11-01-2022, 04:45 PM
                                    • Ihandyrepair
                                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                      by Ihandyrepair
                                      Hi guys
                                      I just started fixing 4k TV few months ago. so I am still learning a lot
                                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                      then it started to show the ghosting white image.
                                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                      it has 3 thin small boards at the bottom of the...
                                      12-05-2022, 04:18 PM
                                    • ggil44
                                      Sony XBR-65X750D Horizontal lines bottom of screen
                                      by ggil44
                                      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                      05-30-2023, 07:51 PM
                                    • noisykid
                                      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                      by noisykid
                                      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                      12-30-2024, 07:15 PM
                                    • x_orange90_x
                                      Samsung UN46C8000XFXZA Horizontal lines
                                      by x_orange90_x
                                      I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                      I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                      07-15-2023, 05:06 AM
