Lg plasma 60pa6500-ug damage
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Im working on a 2012 lg plasma tv that has 6 blown 30f126 mosfets and one bad rf2001.
    I think they failed because the 2 ground/mounting screws in the middle of the zsus board have burned through the board itself. Must have been arcing for a long time!
    I checked to see if that part of the board goes to common ground, but it dont.
    My question is, can I just get to the bare copper, solder on a piece of wire, and tie it to another ground point. Maybe i can use a ring connector and wire soldered to the pad.
    The board is too damaged in those two spots to repair, frickin' charcoal holes twice the size of orig. holes. So..... what do the pros think?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Lg plasma 60pa6500-ug damage
    A picture of the underside of the board showing the damage could help.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Damage pictures.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        If you carefully scrape away the solder resist you should be able to solder a very thin washer to the underside to make the connection good. You may have to snip a little bit off one of the washers for the right hand side hole in the photo so it does not short across tracks.
        • cliff_hootarski
          • Jul 2006
          • 411
          You would think that would have put out a "burned" smell to alert the owner something was amiss?
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            I bought a xsus from ebay and the tv now has a pic, but it looks liks crap.
            Malcharge on bottom of screen, sparkles that somewhat go away when lowering vs voltage, and a lot of image retention. I checked the bottom of x and y sus boards, and touched up most of the solder joints. Maybe checking all the voltages will help but I cant find the ve, vsc and the others correct voltages. Maybe someone can help with those, I will get a pic of the sticker later.
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Prott
              PS5 - long screw damage, via to ground layer short?
              by Prott
              Hello dear Badcappers,
              I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
              Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
              07-27-2024, 08:54 AM
            • ImpossibleRepairs
              Pad repair
              by ImpossibleRepairs
              Howdy good peoples;
              looking for some advice on Pad repairs, want ti expand my skills
              Working on a HP board that went for a swim; There was a short in what appeared to be the Data IC (there was corrupted data that we recovered) ;
              First picture is the donor Board, clean removal;
              Second picture is board im working on; As soon as I started prepping the pads to re work the IC, the damage started;
              As a side note, Im using good equipment M series Thermal tronics iron with a 1.6m tip; Good quality locally produced flux, good quality...
              05-11-2024, 05:19 PM
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
            • Green Probe
              Alienware m15 R5 Ryzen No Power
              by Green Probe
              Hello, I have an Alienware m15 R5 Ryzen, P109f002, with motherboard GDL56 LA-K453P Rev:1.0, Ryzen 9 5900HX, RTX 3070. I got it due to it having liquid damage. I am quite new to chip-level repair, and this is my second post, so please be kind with my incompetence. The charging IC is an ISL95522ah in HPB mode as far as I'm aware. I've been using a schematic for a LA-K455PR10_0525A that is available in the forum, and it seems to match for the most part. If it's okay I can link the schematic, or insert the pertinent page into my post.
              It had some crusty areas that I've cleaned up....
              02-05-2024, 02:46 PM
