Lg 47lw4500
  • Jimmy1979
    • Apr 2015
    • 120
    • holland
    Lg 47lw4500
    Hello
    I got this led tv with following problem.
    I turns on lg logo for 2 seconds then backlight goes out.
    If i put a flash light on the panel there is a image.
    Does someone know if the problem is on the power supply or the mainboard?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Lg 47lw4500
    Bad led's
    • Jimmy1979
      • Apr 2015
      • 120
      • holland
      Re: Lg 47lw4500
      Originally posted by dskall
      Bad led's
      I opened the tv to watch if all leds are on for the 2 seconds.
      All leds turning on no bad leds
      • dskall
        • Oct 2016
        • 2905
        • usa
        Re: Lg 47lw4500
        Need good clear straight on pictures of back of tv with cover off and each board. and picture of connector on power supply board.
        • Jimmy1979
          • Apr 2015
          • 120
          • holland
          Re: Lg 47lw4500
          I will post tommorrow tv is at my parents house.
          • Jimmy1979
            • Apr 2015
            • 120
            • holland
            Re: Lg 47lw4500
            Can i place jumpers to see if backlight working normal?
            Here is the connector from service manual
            • Jimmy1979
              • Apr 2015
              • 120
              • holland
              Re: Lg 47lw4500
              Here are pictures
              • Jimmy1979
                • Apr 2015
                • 120
                • holland
                Re: Lg 47lw4500
                Originally posted by Jimmy1979
                Here are pictures
                Pwr-on 3,3v. 24v = 23,8
                24v= 23,8v. 24v =23,8
                Gnd Gnd
                Gnd. Gnd
                3,5v = 3,4. 3,5v = 3,4
                Gnd. Gnd
                Gnd. Vsync = 0
                12v = 11,7. Drv-on = 3,1
                12v = 11,7. Nc = 0
                12v = 11,7. Pwm = 1,0
                Nc = 0. Error = 3,4v
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Re: Lg 47lw4500
                  Can you provide the voltages at the led connector
                  • Jimmy1979
                    • Apr 2015
                    • 120
                    • holland
                    Re: Lg 47lw4500
                    35,6v this is to low
                    Sometimes tv works and then voltage is 60v
                    I can see darker leds then others in picture
                    Does this means leds no good?
                    All leds burning but some lower in brightness
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Re: Lg 47lw4500
                      Just like post #2. The fact that it is an LG makes it about 90% chance of bad leds. Just been my experience.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Re: Lg 47lw4500
                        60V is the correct working voltage for the leds. You have just confirmed that you have faulty leds (darker leds)
                        • Jimmy1979
                          • Apr 2015
                          • 120
                          • holland
                          Re: Lg 47lw4500
                          I will order a set left+ right and see what happends.
                          • Jimmy1979
                            • Apr 2015
                            • 120
                            • holland
                            Re: Lg 47lw4500
                            I ordered and installed new led strips and problem is fixed.
                            Many thanx for the people who helped me.✌��
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Re: Lg 47lw4500
                              Glad you got the set up and running again. Turn the backlights down to maximise the lifetime of the leds.
                              • Jimmy1979
                                • Apr 2015
                                • 120
                                • holland
                                Re: Lg 47lw4500
                                Thanx for your advice.
                                I did this already👍🏻
