I'm working an a Panasonic TC-42PC2 Plasma curb find. Earlier tests as read here (I believe) pointed to the SS board. Got one off ebay. I installed it and 10 blinks went to 7 blinks.
Did another test found here and the 7 turned into 6 blinks, pointing now to the SN board.
Bought an SN board and installed it. THat was sometime in February. Issue went back to 10 blinks.
Why, I'm not sure, last week I bought a reasonably cheap P board. Installed it other day, still 10 blinks. A board??
Read further on this site and followed the following instructions from another post on a Panasonic 42" 10 blink set.
I copied and edited in my results and some findings in the following text.
New SS board.
Q001 w/ red on top = 47.0k
Q001 w/ black on top = 47.0k
Q002 w/ red on top = 47.0k
Q002 w/ black on top = 47.0k
Q021 w/ red on top = 47.0k
Q021 w/ black on top = 47.0k
Q022 w/ red on top = 47.0k
Q022 w/ black on top = 47.0k
Old SS board, 2 @ 18.?? ohm and 2 @ 0.5 ohm.
I did following test with new (junk?) SN board.
Try this first, tv off, disconnect SS11,SN2, P35, the 3 white ribbons at the A board. Turn TV on and confirm it turns on and no blinks. This proves the P and A boards are not the cause of 10 blink.
Turn TV off Leave everything removed for 5 mins before reconnection, panel can be destroyed if p35 still has charge, sn2, ss11 will have 200v residual for a while.
Assuming that passed. ***Yes, this passed. Steady red LED when turned on.***
Hook everything back up, leave ss3,ss1 removed and turn on . If still 10 blinks I would check out the SN for shorted transistors or check Sn2 connector for low resistance or short
On this last test, it went back to the 10 blinks. I compared transistors on new SN board and found more shorted transistors (0.5 ohms) on the new board than the original board. I checked those marked off in post #28 of that other thread. With out digging out the magnifying glass, are those all the same? Wondering about taking two boards and attempt half a repair and maybe make one work.
I did put in the old SN board and it went back to 7 blinks and then 6 when I disconnected something for that previous test. Looking like the original board is in better shape than the one the guy in FLA sold me on ebay as used/working condition.
I have stuck about all the $$ I can into this curb find. Any other sugestions would be much appreciated. Also, anyone interested, I have a repairable SS board and likely a good P board I could make one heck of a deal on with someone for helping me get this set up and running again.
Thank you in advance,
Dale
New SS board.
Dale
