Element ELEFW327 32" - Standby LED, will not turn on
  • P4RI4H
    • Apr 2017
    • 13
    I can't see any bad capacitors myself, and I tried replacing the EEPROM already. Pics show post-replacement. No broken connections as far as I can tell.
    What steps do I take next?
    EDIT: Will take pics of the opposite side of the board later when I have time if necessary. Also I'm in the process of digging out my voltmeter.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Element ELEFW327 32" - Standby LED, will not turn on
    What tests did you do prior to deciding to change the EEPROM??
    • P4RI4H
      • Apr 2017
      • 13
      None really. TV was left with my parents. I get a power LED for standby mode but nothing else works. figured if it worked then great, but if not, then I'm only really out $15.
      • PNI E.
        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
        by PNI E.
        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
        03-17-2025, 04:23 AM
      • madsox
        Harman Kardon AVR 171S - standby led lights up, does not turn on
        by madsox
        Greetings!
        Thank you in advance for your understanding, I am writing to you through a translator.
        A Harman Kardon AVR171S amplifier was given.
        The history of the machine is as follows:
        It was faulty when I bought it, I want to fix it.
        I replaced the HDMI switch and one of the DAC ICs in it.
        After that it worked without a problem.
        I watched a movie using the amplifier, and at the end the amplifier got really hot.
        The cooling was faulty, I will fix this later.
        I switched it to standby mode, waited for...
        09-24-2022, 10:46 AM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • Adenitz
        Troubleshooting Vestel TV, has standby, but cannot turn ON
        by Adenitz
        I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
        Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
        Both boards are shown in the attached photos.
        What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
        12-27-2023, 03:43 AM
      • twist3r
        Samsung 2693HM - Doesn't turn on (no standby)
        by twist3r
        Hello everyone!
        I'll try not to create big posts this time (though I'm sure I'll fail).
        Ok, here we go...
        Back in 2017. one capacitor on my monitor power board failed, so I had to replace it. I decided to change all the caps (except the BIG one), and everything was working well. I had a big help from other members, especially from momaka. He had enough patience to give answer to all my questions.
        For those interested in reading that topic, here it is: [help required] which capacitor type for monitor power board
        10-24-2020, 04:54 PM
