LG 55LE5400 Flashing and buzzing
  • jason123
    • Oct 2015
    • 1083
    I would greatly appreciate any insight of what this issue could be before I open it up and start the typical troubleshooting. I have and LG 55LE5400 TV, that turns on beautifully, backlight ok, steady picture (logo), then when it fully boots you start hearing a buzz / high pitch, then the picture starts flashing - you can still see the prompts on the TV (like input source selected and so on ) just the buzzing stays and picture continues to flash. I included a short 27 second video since it's difficult to describe this. Any thoughts?
    Thank you
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 55LE5400 Flashing and buzzing
    First thing that comes to mind is LG and failing leds. I would disconnect the LED backlighting from the power supply and then power up the TV and see if the buzzing still occurs. When the picture comes up before it shuts down do you see any dark areas?
    • jason123
      • Oct 2015
      • 1083
      Thanks Freakaftr8 - I will try that a bit later.. it's good start. I wouldn't have thought of it, because the backlight comes on steady while the logo is showing.. it's only when "Other things" start coming on that the flickering starts
      • freakaftr8
        • Oct 2012
        • 3743
        This era of main boards present a problem with bad BGA soldering connections on the nvram for the processor. It will represent themselves in various different fashions that could also be looked at
        • jason123
          • Oct 2015
          • 1083
          So I opened it up and the buzzing was actually coming from the speakers. Disconnecting the LED power from the LED Driver board didn't have any effect.. disconnecting the speakers took care of the buzz, but the picture is still shaky / flickering. Any thoughts?
          • freakaftr8
            • Oct 2012
            • 3743
            Have a look at this post and try the methods within and tell us if you have results
            https://www.badcaps.net/forum/showthread.php?t=61321
            • dskall
              • Oct 2016
              • 2905
              • usa
              With buzzing speakers could be a bad cap on mainboard. Possibly power board. You could go around and check across caps with meter set on ac and see if any measure higher than others.
              • jason123
                • Oct 2015
                • 1083
                Thank you.
                dskall, am I looking for higher ESR or Shorted? higher ripple?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Might have a look at this :https://www.youtube.com/watch?v=LvXe0bOF_mk
                  • jason123
                    • Oct 2015
                    • 1083
                    Thanks Dskall. Good video. I've done something similar, but given most capacitors are on different regulators, I don't have something to compare to. Here is some more info:
                    - The Ethernet port is not powered (when connected to a network switch - no activity)
                    - Firmware upgrade through USB results in no activity. Though I see the USB being powered up, for some reason, the system doesn't detect the presence of a USB flash drive.
                    - Menus for Network have Network config and Network status greyed out.
                    -Only power coming into the board is 24 V and that seems to be solid (24.16 V)
                    - I checked many capacitors on the main card, and they all read either 11.9, 3.3, 1.5, 1.8.. which is typical from what I recall.. one set of caps is reading 7.8 V which is odd.. I don't remember that voltage rail on other board. These are the C9114 and C9115 (assuming someone has a schematic for this EBU60884404)
                    Thoughts?
                    • jason123
                      • Oct 2015
                      • 1083
                      Just to note.. as the TV warms up.. the buzzing noise quiets down quite a bit.. and the flashing stops.. but still no Network or USB access
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Like I said suspect BGA rework on the NV Ram modules around the processor try heating them up and see if the problem goes away as a TV starts up cold..... these are located underneath and around the black heat sink
                        • jason123
                          • Oct 2015
                          • 1083
                          Thanks Freakaftr8.. I have access to a reflow machine and technician.. it's going through that now.. I'll update shortly.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Sounds good but I wouldn't not go through the process and Reflow unless necessary. A simple hair dryer will do the trick while the TV is on cold
                            • jason123
                              • Oct 2015
                              • 1083
                              Thanks Freakaftr8 .. great success with Reflowing the processor. I'm getting almost all functionality back, except the Network!
                              This unit has Ethernet port and it's "WiFi" ready. The Ethernet port is not showing any activity what so ever. Options in Menu still greyed out, LEDs on the connector stay off even when there is a good link... any suggestions? I updated the Firmware using a USB drive - so that was great..
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Interesting. Ethernet internally is not getting powered. Can you factory reset? It's in the settings menu.
                                • jason123
                                  • Oct 2015
                                  • 1083
                                  I did.. then I upgraded firmware and tried again.. still greyed out for some reason
                                  • IAmOrion
                                    LG55UB850V no picture or audio, just flashing LED's help please?
                                    by IAmOrion
                                    Hi members, I came across this forum when searching a fault on my LG 55UB850V TV.
                                    Rather than hi-jack another members post/thread I thought I should start my own even though it's an almost identical issue.
                                    The thread I refer to can be found here:
                                    https://www.badcaps.net/forum/troubl...-s-help-please
                                    My boards are the same, and my issue it the same. I have NO Picture and NO Sound. Nothing. When first turning on the TV at the...
                                    01-28-2024, 06:50 PM
                                  • maricm
                                    Vizio m65-c1 picture flashing on and off on the screen
                                    by maricm
                                    HI all,
                                    hope someone point to the possible issue before I start buying replacement parts.
                                    Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                    Backlight stays on all the time,
                                    Sound works fine.
                                    screen keeps changing form black to full picture in about 1sec intervals.
                                    Picture looks fine with no visible artifacts.
                                    I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                    Disconnecting left and right ribbons on...
                                    11-25-2023, 06:32 PM
                                  • Tr0ll
                                    by Tr0ll
                                    Original T-con:
                                    First replacement T-con:
                                    10-07-2023, 07:48 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • DXseekerMO
                                    Vizio P502ui-B1E, delayed video, white flash, flashing picture UGH!!!
                                    by DXseekerMO
                                    About a week and a half ago this TV was traded in to me with the complaint: upon turning it on one morning a white blob slowly spread across the screen. Before I got it the TV had been sitting about 3 weeks. I also found the RF IN connector was missing. I turned it on for evaluation and got the splash screen/menus.
                                    I installed a 75ohm RF connector, repaired several bad grounds on the power board and chassis, checked all boards for loose screws and cleaned the entire inside of the TV. After all appeared well, the TV was tested for 40 hours and was subsequently put up for sale. ...
                                    05-07-2019, 07:20 PM
