forget to isolate sd/su 4 hv screws=blown sc
  • bman4
    • Jul 2015
    • 210
    • canada
    got 7 blink did what i though was isolating the sd/su buy unplugging them but leaving the 4 screws.
    there was a loud pop then i notice ic 748/mip 391 burnt along with front row igbt's shorted.
    i need to know if anything else got damaged since the surge hit all the way to mip391.
    the question is how much damage can this cause to sc
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: forget to isolate sd/su 4 hv screws=blown sc
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • bman4
      • Jul 2015
      • 210
      • canada
      It was a low voltage section that involed the pic ic but forget what i replace but it was more than just that.
      I tried using a sub part on a 42 and it arcked it while jumping sc50 lol i still got shell shock from it . i m working on a 50u50 and. Used a sub fairchild fgpf4536 to replace dg302 and was dam sure it was gonna happen again.
      Dg302 is 300v 250a when 4536 is a 400v 200a . i tried it once and it failed with.green square in ceter top. I strated.researching and found tw2005 posted.fairchild.4536. Is ok an i had.1.left on the 60 inch samsung x main andnit been worjing for 24 hours . i aspen a good 8 h cleaning and tighting everything.
      • rivetcity
        Panasonic TX-P42UT30E, IGBTs on the SN board
        by rivetcity
        I'm having problems with my plasma Panasonic p42txu32e. The issue started about 12 months ago.
        I have a remote controlled main outlet so whenever I turn off the TV set at night, I also switch off the whole power outlet.
        It gives me a better feeling to know I don't have 230V on any cables, so my dog can't get hurt if he gets the idea to start chewing on something.
        About 12 months ago the TV started to have the following problem: when pressing anything on the RC to get it on, the red led would go off.
        Sometimes it would turn...
        08-12-2021, 01:25 AM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • Biruslapio
        Samsung PL42C450 plasma X-Main IGBTs
        by Biruslapio
        Hello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
        It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
        Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's...
        04-08-2022, 01:16 PM
      • xFaydra
        Help, forget Bios Password Lenovo Legion Slim 5 16APH8
        by xFaydra
        Hi guys i need some help please. I want to enable secure boot lately to play game, but I don't remember my bios password i set before. My laptop is Lenovo Legion Slim 5 16APH8. If someone can help i will be very thankful
        07-07-2025, 12:15 AM
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        Yesterday, 12:34 PM
