Bad Receiver?
  • Patch2
    • Jul 2016
    • 30
    Bad Receiver?
    I have a few month old Toshiba 50" flat screen LED, that I have connected to an OTA antenna. It was working fine, but recently it stopped picking up OTA signals, on all but the absolute closest station (like 11 miles away). There was a power outage around the time is stopped working, but that has never affected any TV I've ever had before. The antenna is in good shape, solidly connected, so no problems there. Could the receiver be partially burned out?
  • Patch2
    • Jul 2016
    • 30
    Re: Bad Receiver?
    BTW, from the day I bought it, it didn't get as good reception as the TV it replaced.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Re: Bad Receiver?
      Maybe problem with cable. Does it have a signal amplifier?
      • Patch2
        • Jul 2016
        • 30
        Re: Bad Receiver?
        No amplifier. How can I test the cable?
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Re: Bad Receiver?
          TV tuners can have different signal gains (amplification) so a weak signal can be received by a high gain tuner but not necessarily by one with a lower gain.
          Have you tried a factory reset or firmware update.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Re: Bad Receiver?
            If you have another tv does antenna work good with it?
            • Patch2
              • Jul 2016
              • 30
              Re: Bad Receiver?
              I thought so. I've always wondered about that. Thanks for the confirmation. But no, I have not tried a factory reset or firmware update. How do I do either of those?
              • Patch2
                • Jul 2016
                • 30
                Re: Bad Receiver?
                No I don't, but I've been looking for a cheap used one, at the thrift store, just to use as a test unit.
                • Patch2
                  • Jul 2016
                  • 30
                  Re: Bad Receiver?
                  Never mind, I figured it out. There are no firmware updates at this time. I'll try the factory reset, and let you know.
                  • CapLeaker
                    Leaking Member
                    • 8116
                    Re: Bad Receiver?
                    btw, the amplifier goes close to the antenna, as you want to amplify signal, not noise. I've noticed that some TV's have a built in LNA (low noise amplifier) in their tuners which can be turned on or off in the tuner menu.
                    • Patch2
                      • Jul 2016
                      • 30
                      Re: Bad Receiver?
                      I don't see how it can be a matter of adding a pre-amplifier at the antenna. I've thought of that. But it's not like there is a weak signal, there is just no signal at all for about 10 stations, all of a sudden. They were working for several years with the same antenna I have now, and now they are not. FOX, the most powerful station is 1000kW at 38 miles away. I should get some indication that that station exists, but I get static. That's why I am questioning the tuner itself.
                      • mu2
                        • Oct 2009
                        • 217
                        Re: Bad Receiver?
                        I have had to replace the tuner on a 46" Samsung that I got from the recycling center.
                        I was fortunate to have a scrap board with the exact same tuner and swapped them. On this tv the side hdmi port didn't work and it was obvious that the chip was burned. I suspect that some kind of surge or lighting strike took out the parts.
                        So in my experience, the tuner can fail giving you no reception. Are all the hdmi inputs working? If both the tuner and hdmi are bad it may have been a surge that took them out.
                        There are external hd tuner boxes that are pretty inexpensive. The ones I have seen use the hdmi port to pass the signal to the tv. So that would be a way to still use the tv without replacing the internal tuner.
                        MCM Electronics carries such a tuner. If you want to spend a lot more money with more features check out the Channel Master DVR+.
                        Mike
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          Re: Bad Receiver?
                          i take it you re-scanned the channels ?
                          • Patch2
                            • Jul 2016
                            • 30
                            Re: Bad Receiver?
                            Yes...couple of times.
                            • Patch2
                              • Jul 2016
                              • 30
                              Re: Bad Receiver?
                              Factory reset did not help. Same issue remains.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Re: Bad Receiver?
                                Just trying to rule out easy possibilities first. Cable connections cause a lot of problems. May well be tuner problem.
                                • hugocarmo
                                  Jvc hr-d470eg
                                  by hugocarmo
                                  Hi everyone.
                                  I bought this vcr, I don´t know if you are like me, but I´ve never heard of a vcr with a side loading mechanism...
                                  It was working, but the only problem was that as I loaded the tape, it started playing and a second after stopped, FF an RW equal.
                                  I have seen some youtube videos that showed that maybe was the reel sensor, the only difference was that mine, changed the counter from 0000 to 0001 or 0002, so I was not convinced that it was the problem... Dispite that, I connected my bluetooth receiver through rca cables to input, and I only had left channel in stereo,...
                                  08-11-2023, 05:54 PM
                                • Capestang
                                  Yamaha DSP-AX861SE Sub problem
                                  by Capestang
                                  I really hope someone will be able to help me?
                                  I have recently moved house and dismantled a working 5.1 home cinema
                                  system. Unfortunately when putting it back together again I get no
                                  sound out of the sub, I'll try and give you as much (probably too much)
                                  information to hopefully allow you to sort my problem, or at least
                                  point me in the right direction.
                                  * My system consists of a Yamaha DSP-AX861SE AV receiver connected to
                                  various sources and outputting through speaker cables to 4 x Monitor
                                  Audio Radius 90s, 1 Radius 225...
                                  01-24-2023, 04:00 AM
                                • jason123
                                  Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
                                  by jason123
                                  Hello folks,
                                  New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
                                  05-27-2025, 07:26 AM
                                • CdDvdFlash
                                  DSE GE6878 possible TV receiver dying remote not working well
                                  by CdDvdFlash
                                  For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                  07-03-2024, 03:55 AM
                                • survivalbloke
                                  Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                  by survivalbloke
                                  This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                  06-25-2025, 12:20 PM
