Samsung UN60D8000YFXZA Power Supply clicking
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4542
    • Italy - Milan
    Re: Samsung UN60D8000YFXZA Power Supply clicking
    OK, the WIFI module is arrived to me, tested GOOD with 2 hours of Youtube videos, 1 hour of TV. Forgot to test the antennas.. thanks, bye.
    • casino187
      • Aug 2017
      • usa
      I'm having the same clicking and blinking light. When I unplug the main board from power board, the backlight will light up and TV turns on. I have tried unplugging the individual cables from the main board to narrow down the issue but even with them all unplugged the TV will still click. Only way to get it to work is unplugging the main board. I'm unable to unplug only the wire that goes the the buttons/IR sensor because I can't turn on the TV with these disabled. So I guess I can't rule that out.
      TV started doing this after a storm. Does this in any way rule out a bad power board? or could it still be the power board considering it works when the main board is unplugged and doesn't have a full load? There are no visually bad/puffy capacitors on the power board either. Thank you guys for your help in pointing me in the right direction. I'm no TV expert, but I'm learning a lot and fast.
      • casino187
        • Aug 2017
        • usa
        Originally posted by brucetv
        I have a Samsung UN60D8000YFXZA Tv in the shop that I can't seem to pin point what's wrong. When you plug in you can hear a double click from the area of the transformer and the led also has 2 short blinks with no picture.
        Also, this is the same model number TV as brucetv ,
        • casino187
          • Aug 2017
          • usa
          Just to update in case it helps others. I replaced the main board and now the TV is good to go.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
            09-07-2024, 05:50 AM
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
            03-31-2024, 02:12 PM
