Gamma driver IC's Voltage buffers.
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    Hello everyone and have a nice day !
    I have this question:
    On samsung TV's the Tconboards use AS15-F chip and AS19-H1G.in advance
    Are this two chips the same ? can i replace one with the other ?
    Is there any real difference between them ?
    Thank you in advance !
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Gamma driver IC's Voltage buffers.
    Don't think they are interchangeable
    https://cdn.badcaps-static.com/pdfs/...96ac888b1b.pdf
    https://cdn.badcaps-static.com/pdfs/...61ea6520a5.pdf
    • diif
      • Feb 2014
      • 6978
      • England
      No. They aren't interchangeable.
      • HellasTechn1
        • Sep 2015
        • 176
        • Greece
        Thank you for informing me !
        Have a nice day
          MAX9590ETU+ MAX9590 Datasheet
          The MAX9590 provides 14 programmable voltage references and four static voltage references for gamma correction in TFT-LCD displays. Two register banks are provided to store two sets of gamma reference values. Gamma values are programmed into the banks through the I2C interface and the outputs can switch between values in 0.5µs.
          The 14 programmable reference voltages are divided evenly into seven upper and seven lower voltages for the upper and lower gamma curves of LCD column drivers.
          Each gamma reference voltage has an 8-bit digital-to-analog converter (DAC) and isolation...
          10-07-2024, 04:18 AM
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • rddube
          Lenovo L490 Ram voltage circuit malfunction
          by rddube
          Hello friends,
          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
          07-15-2025, 04:41 PM
        • Fernon@Repair
          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
          by Fernon@Repair
          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
          VCCIO voltage ok
          VCCSA Voltage OK
          VCCPLL Voltage OK
          Ram Voltage ok
          RamVTT OK
          VPP 2.5 OK
          But No Core Voltage
          and i want to this vrm ic datasheet or pinout (ISL69269)
          anyone have this ic pinout voltages?...
          06-25-2025, 07:19 AM
        • electron_jj
          Panasonic TH-L42D25A checking the PSU output voltage
          by electron_jj
          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
          08-29-2021, 08:13 AM
