Sharp 70 LLC-70UD27U Cracked Screen
  • Dcolliau
    • Mar 2017
    I unfortunately have cracked my screen trying to hang the TV by myself after painting. There is a smiley face crack at top about 15" wide and 4" deep at the deepest point. Is there a way I can use this tv without having it short out and do the 5 -2 code? I was able to get the back light on by disconnecting a couple of the driver boards along the bottom of the frame. I wasnt sure if "tabbing" was an option to make it work.
    Thanks in advance.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sharp 70 LLC-70UD27U Cracked Screen
    A cracked screen you say....Part it out and sell Boards on e-bay or Amazon.
    • Dcolliau
      • Mar 2017
      That's where it will end up. I was just curious if it's usable at all. I will take that as a no. Thanks
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • Mad_Science
        Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
        by Mad_Science
        I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
        03-01-2024, 05:05 PM
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
