Pioneer Plasma Pro 1120HD fixable or Not? 2 pictures shown
  • heavymachines
    • Mar 2011
    • 1028
    Re: Pioneer Plasma Pro 1120HD fixable or Not? 2 pictures shown
    eBay item number:221961865013 punch that in ebay search is the cheap tester. Other meter is the anatek blue esr tester also available on eBay.
    321963237498 ebay item number.
    EDIT: here is a better one with leads i made my own.
    • freakaftr8
      • Oct 2012
      • 3743
      You could try a lighter to the cap. Just hit it softly and see if the pic comes back. But I'm pretty.sure that cap is the culprit. It's been a while and I should have really noted which cap it was but if my mind seevwa me right I'm pretty sure it was c2304 I remember now it being right near the connector.
      • freakaftr8
        • Oct 2012
        • 3743
        If you don't have a lighter you can use the tip of your soldering iron and hold it to the aluminum top of that cap to pinpoint which cap is causing the problem. Just don't hold it on there for too long
        • Boyd1966
          • Mar 2017
          • 128
          I heated each cap with a funnel. The funnel was completely isolating each cap. The cap that made the picture come up is the one in the picture circled in red.
          It is a 350v 3.3 uf. I have a 315v 22uf. Probably not but can I use the 315v 22uf as the replacement? If not, is this the cap I need to order? https://www.digikey.com/product-deta...R3B-ND/2688936
          • freakaftr8
            • Oct 2012
            • 3743
            Yes order that cap from digikey. Don't use your 22uf it will not yield good results. Sorry I should have noted c2302 before. It's been a couple years since I've done this repair
            • heavymachines
              • Mar 2011
              • 1028
              ignore.
              • Boyd1966
                • Mar 2017
                • 128
                I realized the Panasonic are only in bulk. I found these. They look the same but would like confirmation. Can you check?
                https://www.digikey.com/products/com...493-11880-1-ND
                I did find this Panasonic but it is 400v but says 2000hrs. The one above is 5000hrs.
                https://www.digikey.com/product-deta...459-ND/2688899
                • heavymachines
                  • Mar 2011
                  • 1028
                  493-5174-1-ND digikey part number, 350v 3.3uf rated 5k hours can order single.
                  • Boyd1966
                    • Mar 2017
                    • 128
                    Great thanks Heavy and freaky. Ordered.
                    • Boyd1966
                      • Mar 2017
                      • 128
                      Re: FIXED!!!!! Pioneer Plasma Pro 1120HD fixable or Not? 2 pictures shown
                      SUCCESS!!!!! Its fixed! She started right up with a clear picture. She is like new!
                      Thank you all who responded with special thanks to freakaftr8 and vinceroger69. And a VERY special thanks to Heavymachines. I wouldn't have had a clue how to fix it if it wasn't for you helping me.
                      I was going to throw the TV away and buy a new one but all it took was some diligence, know how, and a .68 cent capacitor.
                      I made a donation to the site. Very well worth it.
                      Boyd
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Great news Boyd! TV should last you more years of good use. Afterall it is a Pioneer. One of the best even being older. And thanks for the donation. We're always here to help.
                        Shawn
                        • Boyd1966
                          • Mar 2017
                          • 128
                          Thanks Shawn. I can't tell you how proud I feel. Just another notch on my never have done but did it list.
                          So with this TV, what other things might go wrong? I know it is vague but just want to poke your brain.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Honestly with TVs this really hard to say. Maybe power supply related problems eventually low voltage conditions causing sparkles or a possible buffer board failure although Pioneer and buffer board failures are extremely rare. Maybe a trap switch eventually going bad if you have one. That's about all I can think of
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Boyd
                              Great news. Glad we were able to help. Another one saved from the landfill. Pat yourself on the back and have some popcorn!!
                              • Boyd1966
                                • Mar 2017
                                • 128
                                Thanks Heavy.
                                • Phil Stasik
                                  Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
                                  by Phil Stasik
                                  Pioneer Pro-FHD1 Elite. Failure to power on.
                                  I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
                                  We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
                                  01-19-2023, 01:22 AM
                                • Bushcat
                                  Pioneer PL-X9 motor speed control wobble
                                  by Bushcat
                                  I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                  Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                  BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                  05-24-2023, 03:36 AM
                                • Wiggly_worm
                                  Pioneer plasma panel fault codes
                                  by Wiggly_worm
                                  Has anyone had any experience with with pioneer plasma panels, this one is in an NEC PX-42XR4G and it powers up for around ten seconds then goes into standby with a red led on digital board flashing six times and refuses to power up !...
                                  02-24-2020, 09:55 AM
                                • RatherLoopy
                                  Pioneer VSX-44 receiver HDMI dropouts
                                  by RatherLoopy
                                  I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                  I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                  And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                  05-26-2023, 03:54 PM
                                • Evets
                                  Pioneer sg530
                                  by Evets
                                  This forum has been so useful to me and I thank all the people who have helped me in the past.
                                  I'm now in need of some more assistance, I have purchased a Pioneer sg530 graphic equaliser to add to my Pioneer X-G7 hifi system. This equaliser was a factory option on this system but as this was purchased second hand I didn't get a user manual. Searching the internet has been fruitless, can anyone help with a schematic of how this should be wired into the system or possible a copy of the user manual.
                                  07-30-2024, 07:18 AM
