Samsung un55h6203afxza us01 no backlight
  • crdz66
    • Nov 2012
    • 242
    Hello.
    I need you value opinion on this case.
    This tv show sound but not backlight or video.
    The original ps show really on led drivers connector high value on m1+ but almost 0v on m2+,m3+,m4+ and m5+
    that make to take the decision replace not only ps if not the all kit include ps, main board and t-con board.
    But still show the same symptoms.
    No backlight, no video but sound ok.
    The connections on ms1 still remain on 280v-320v fluctuating and another m+ remain 0v.
    What i doing wrong or new ps is bad?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung un55h6203afxza us01 no backlight
    Need pictures and voltages
      Sounds like open circuit in the LED string but we cannot really tell much until we see good clear hi res pictures of the whole back side of the TV and the boards.
      • crdz66
        • Nov 2012
        • 242
        Ok.
        Connector CNM803 (Main-PS)
        1,3,5,7 are 12,7v
        9 is 0v
        2. 2.3v
        4. 3.2
        6. 4.4v
        8,10 gnd
        connector cnl802 led driver (connect to led strings)
        m1+ - 280-320v floating
        m2+, m3+, m4+, m5+ = 0-7v floating
        connector cnl802 led driver (w/o connected)
        m2+, m3+, m4+, m5+ = 0-.3v floating
        Additional comments.
        As soon turn on the tv, after 3 secs, you can see a quick light from backlight but less a second. The light is really poor not intense.
          http://www.shopjimmy.com/samsung-bn4...led-board.htm#
          BN44-00774A.
          You have open circuit in the LED string, the LEDs are connected in series to form one long string.
          The M1+ is the Anode of the first LED in the string and the M5- is the Cathode of the last LED in the string.
          Pictures provided by shopjimmy
          • crdz66
            • Nov 2012
            • 242
            dump question.
            Do I need replace power supply board?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              No. You need to strip your panel down to the LED backlights and replace any LEDs not working.
              • crdz66
                • Nov 2012
                • 242
                But, even if led connector is not connected I still have the same readings.
                I understand when is connected can have open circuit because the low readings, but what happend when is not connected???. How can open circuit is detected?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  When a led(s) is open circuit no current flows and the Led driver chip detects the lack of current flowing so is the same as not plugging in the leds.
                  • crdz66
                    • Nov 2012
                    • 242
                    Thanks.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      +100
                        09-07-2024, 05:50 AM
                      • sansanpartida
                        Samsung QE82Q70RAT no backlight
                        by sansanpartida
                        Hi everyone!
                        Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                        My issue: No backlight.
                        Model: QE82Q70RAT
                        Type No: QE82Q70RAT
                        The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                        So hopefully, I can fix this cheaper.
                        05-22-2024, 06:56 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • Warrensmith
                        Samsung BN44-00807E Low Backlight
                        by Warrensmith
                        Symptom is dim backlight - this set came in with almost no backlight.
                        Samsung UN55JU6500FX2A
                        1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                        2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                        Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                        10-27-2022, 07:09 AM
                      • Max514
                        Samsung UN55H8000 sound but no backlight no video
                        by Max514
                        Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                        The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                        I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                        • Unplugging the main board cable at the power supply >>> backlights came on.
                        • BLU_ON signal from the
                        04-14-2022, 10:34 AM
