E500i-b1 piece of **** backlight problem
  • freakaftr8
    • Oct 2012
    • 3743
    Re: E500i-b1 piece of **** backlight problem
    Right I opened the screen of the last time I had it in all LEDs were functioning
    • jhrsmail
      • Jan 2017
      • 36
      Any updated info on this??
      • pocketwatch62
        • 74
        • US
        freak,
        did you ever find the problem with this set?
        I have the same set with the same problem.
        • bembeno
          Adapter 24 volt problem
          by bembeno
          I have 24 volt adapter when i measure its output with multimeter i found the 24 volt is good put it dosent charging the battarey of Electric wheelchair i tried another adapter and charging thr battarey what can be the problem
          06-06-2024, 12:32 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Kingblue
          Asus G750JX/JW problem with kb lights, USB ports and touchpad / Bios Problem?
          by Kingblue
          Hi im new here and i hope you guys can help me maybe.
          I buyed an old Asus G750JX and the seller told me it was running perfect after shutdown it never bootet again.
          So i buyed this G750JX and open it. after cleaning and checking all inside i startet it.
          It was booting perfectly. i played a clean win 8.1 on it.
          After installing all and update all to the last drivers it was running very good.
          Thinks that dont worked
          Keyboard back lights and cant start with fn+f4 all other fn+f working
          3 of the 4 USB 3 Ports are not working.
          the...
          03-20-2024, 05:31 AM
        • ahmarzo
          ThinkPad x230 volt in problem
          by ahmarzo
          Have a ldb -2 11232-1 laptop motherboard with no power problem.have 19v on the gate of q51 therefore voltage doesn't pass through the mosfet please help me solve this problem. here is the link for schematics https://www.badcaps.net/forum/attach...1&d=1528192143
          11-03-2023, 07:51 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
