Samsung TV, sound ok, backlight ok, no picture - model LE32S71B
  • Ancymon0
    • Mar 2017
    • 13
    • Poland
    Re: Samsung TV, sound ok, backlight ok, no picture - model LE32S71B
    As promised, giving feedback about repair results. After replacing t-con tv is working, replacing caps get rid of double-triple restarting when powering tv with hdmi to laptop and buzzing sounds from back of tv (i could see that laptop screen was blinking couple times before it finally connected, now it always works on 1st attempt)
    final cost
    damaged tv - free
    caps ~ 2 dollars
    t-con ~ 11 dollars
    What i've noticed
    on broken t-con part KL5T3001 didnt even get warm, on working t-con you can just feel it's working, quite easy to get purpose of metal t-con cover connected with thermopad to this part. There was a lot of dust in tv(it is like 10 years old, 2006 or 2007 release, never cleaned), quite possible it just fried because of heat and completely dusted ventilation ribs
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Thanks for the follow up which could prove useful to others.
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • gl4709
        Samsung un55cu7000d with backlight and sound No Video / Picture
        by gl4709
        I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
        01-23-2025, 06:21 PM
      • LaPCon_IT
        Samsung UE50TU7099U no picture no sound, backlight present
        by LaPCon_IT
        TV has one combo board (VTT55UH160). Symptoms are like this.
        When part of the screen is disconnected (white part), it looks like this
        Resistance and voltages (I don't know if they are good or not). The inductor with 0ohm/0V seems to be connected to GND.
        I haven't noticed any shorts on rails listed below:
        VGH - 30V
        VGL- -9V
        VAA - 14V
        VCOM - 5.6V
        STV - 11.95V
        LC1, LC2 - +30/-12V
        All CKV lines (no shorts between them) looks the same:
        I've tried to cover some lines with...
        12-15-2023, 03:55 AM
