Identify LG TV chip.
  • philly
    • Mar 2017
    • 4
    • Ireland
    Hi All,
    I need help with an LG 37ls570t TV power supply. I need to identify ic601 on the power supply board ( type eax64405901). The ic is used to drive the power factor FET and its part number begins with FAN ????. I cannot see the rest of the part number. Cannot find a diagram anywhere. Any help appreciated.
  • petehall347
    • Jan 2015
    • 4422
    • United Kingdom
    Re: Identify LG TV chip.
    might be FAN7530 .. try a magnifying glass and different light .
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      A magnifying glass and torch. If you angle the light shone on the IC it helps in read the lettering.
      • satinser
        • Oct 2012
        • 214
        Over 3 years to late but hey better late than never.
        Its a FAN 7930BG.
        Hope this helps anybody referring to this in the future!
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          by SMDFlea
          Bad...
          09-02-2021, 04:40 PM
        • AJ847.63e
          Latitude 5521 - broadmoor 15 TGL-H 12L 5v 600ma can anyone identify this chip?
          by AJ847.63e
          got a latitude off of a old colleague which is stuck at 5v and not turning on no signs of life.
          ive done some digging and it seems like pu4501 (5193 ti 1a8 adgh is the chip markings) is shorted. Getting up to around 74c. Haven't removed it yet because i haven't been able to confirm what chip it is.
          Googling the markings brought up only one result, tps 51396 but the markings are 51393 so I'm assuming it's a tps51393 but googling that it seems like the chip engravings are different to the one I have so I wanted to confirm whether my assumption was right...
          07-02-2024, 06:41 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • Troystain
          Help EZP2023+ updated chip database for w25q256jveq?
          by Troystain
          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
          I need to add w25q256jveq chip but I do not know what data should I type.
          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
          11-25-2024, 12:53 AM
