Sony KDL-32P5600 & KDL-32EX302 panel swap
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I got several televisions that are out of order one way or another. Amongst those I got what appears to be a bricked KDL-32P5600 and a KDL-32EX302 with a broken screen. There's another 32" TV from Philips 32PFL5405H/12. This one has a short circuit somewhere in the PSU and it just blows the fuse. I wanted to swap screens but after looking at both Sony TVs I'm not sure this would be doable.
    What would be my best bet here? Thanks
    EDIT: just figured 32EX302 is not a 1080p panel so swapping wouldn't make sense anyway. Maybe that Philips panel could be made to work?
    Re: Sony KDL-32P5600 & KDL-32EX302 panel swap
    You need to look up the spec sheet of the LCD panel to verify T-CON connector pinout, the Voltage and current requirement.
    The Voltage and current requirement for the backlights circuit, etc.
    • r3vsEngIT
      Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
      by r3vsEngIT
      65x900h with the panel from a 65x930d.
      900H: model yr 2020, Samsung panel
      930D: model yr 2016, Innolux panel
      spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
      the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
      07-11-2023, 11:11 AM
    • iglitare
      by iglitare
      09-04-2025, 07:13 AM
    • guidodroid
      Bad Panel in Sony Bravia X850G
      by guidodroid
      Hello all,
      I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
      It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
      Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
      The issue is not as bad as others that I've seen around, but is indeed noticeable...
      03-19-2022, 12:08 PM
    • PlanB
      Sony KDL-55W828B Hotspot in LCD panel
      by PlanB
      Hello everybody,
      I need your expertise if my asumption about the failure of this TV is correct.
      A Sony KDL-55W828B only shows vertical red stripes that vanish to the top when switched on.
      When only the right side of the LCD is plugged into the T-CON board the right side shows a good image, while the left side is white.
      When only the left side of the LCD is plugged into the T-CON board the LCD shows a complete white image.
      I checked some signals on the T-CON board but was not able to find something strange. Then I checked the the caps...
      02-05-2022, 09:46 AM
    • swrb898
      Sony KD-70X690E Bravia; Bad TCON? Bad panel?
      by swrb898
      What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
      Problem:
      Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
      My troubleshooting got me this far:
      With the left-hand TCON to bottom-board ribbon cable...
      12-28-2021, 08:12 PM
