Sony KDL-32P5600 & KDL-32EX302 panel swap
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I got several televisions that are out of order one way or another. Amongst those I got what appears to be a bricked KDL-32P5600 and a KDL-32EX302 with a broken screen. There's another 32" TV from Philips 32PFL5405H/12. This one has a short circuit somewhere in the PSU and it just blows the fuse. I wanted to swap screens but after looking at both Sony TVs I'm not sure this would be doable.
    What would be my best bet here? Thanks
    EDIT: just figured 32EX302 is not a 1080p panel so swapping wouldn't make sense anyway. Maybe that Philips panel could be made to work?
    Re: Sony KDL-32P5600 & KDL-32EX302 panel swap
    You need to look up the spec sheet of the LCD panel to verify T-CON connector pinout, the Voltage and current requirement.
    The Voltage and current requirement for the backlights circuit, etc.
    • r3vsEngIT
      Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
      by r3vsEngIT
      65x900h with the panel from a 65x930d.
      900H: model yr 2020, Samsung panel
      930D: model yr 2016, Innolux panel
      spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
      the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
      07-11-2023, 11:11 AM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • rimwall
      Sony KD-65x7500D - double image - Tcon or Panel?
      by rimwall
      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
      11-18-2025, 02:09 AM
    • guidodroid
      Bad Panel in Sony Bravia X850G
      by guidodroid
      Hello all,
      I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
      It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
      Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
      The issue is not as bad as others that I've seen around, but is indeed noticeable...
      03-19-2022, 12:08 PM
    • PlanB
      Sony KDL-55W828B Hotspot in LCD panel
      by PlanB
      Hello everybody,
      I need your expertise if my asumption about the failure of this TV is correct.
      A Sony KDL-55W828B only shows vertical red stripes that vanish to the top when switched on.
      When only the right side of the LCD is plugged into the T-CON board the right side shows a good image, while the left side is white.
      When only the left side of the LCD is plugged into the T-CON board the LCD shows a complete white image.
      I checked some signals on the T-CON board but was not able to find something strange. Then I checked the the caps...
      02-05-2022, 09:46 AM
