JO47BAIRD power problem
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: JO47BAIRD power problem
    It could be one of the mosfet on the circuit board or even one of the capacitors but they are under the metal shielding so I would remove the shield for this test.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      +1 as you say can be any part on these boards causing the issue
      • cvel
        • May 2015
        • 64
        Its running OK with no back on it by an open window but transformers on the inverter boards are 64 degrees power board 30 degrees but the screen is testing 34.7 degrees which seems a little hot to me but I'm no expert in this field. I'll remove that metal shielding from them caps and test again shortly and let you know. Thanks again for your help
        • cvel
          • May 2015
          • 64
          Another update ive put the back onto the TV as it was working OK once back todlgether I plugged back in and tried to turn it on the screen flickered on I heard walhat sounded like a spark type noise then it went back onto stand by I left it 15 minutes tried again and all is working again.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            that spark noise could be from a few places but as you have found heating that one invertor board makes the fault appear quicker maybe there is a fault on that board as it makes the high voltage (and could make a spark like noise) as its for the ccfl tube voltage but in the mean time as you have had all the boards out make sure theres no trapped wires under them and make sure all the ground screws are tight.
            • cvel
              • May 2015
              • 64
              #26
              Thanks for the advice. Are these boards repairable I repair kitchen appliances for a living so I'm OK with a bit of soldering if needed. I read on another site someone had very similar symptoms with a Toshiba TV and it was dry solder joints in the inverter somewhere soon as the kids have gone to bed I'll check all this but I don't understand how dry joints would create excessive heat this TV didnt cost me anything so I'm happy to have a play about with it and if needed spend a little on getting it going.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                These boards are usually really cheap on ebay etc sometimes its just not worth repair if you have a esr meter you could test the capacitors for uf and esr as maybe failing with the heat on that board a spark noise could be from a winding on the transformers i guess if breaking down etc, hopefully budm or dick-barton may have more ideas too regarding this fault im still learning so others with more experience may have other tests etc.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Inverter transformers sometimes need to be re-soldered but also check the electrolytic capacitors on the board.
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Duranitron
                    Asus x512dk rev 2.1 power on problem
                    by Duranitron
                    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                    11-26-2024, 10:22 PM
                  • EazyBone
                    LG OLED55C9PUA power problem
                    by EazyBone
                    Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                    Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                    I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                    The power supply to t con is different story.
                    This...
                    06-23-2023, 07:43 AM
                  • Dr.d
                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                    by Dr.d
                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                    04-05-2024, 11:48 AM
                    03-31-2024, 02:12 PM
