Hitachi LE42H508 no power....
  • Bullykatz
    • Mar 2017
    • 6
    • usa
    Powered down while watching, unplugged from wall, checked outlet, replugged, came back on for about 3 minutes then died and never came back on.
    If I unplug it, wait and replug and power on, I sometimes get a momentary blue horizontal "strobe" and that's it.
    Did some online reading, took off the back cover and using a multimeter, checked the fuse for continuity (good) but could not get any DC volts outbound from the power supply board so I ordered one. Got it today and.... no change.
    So what else could it be? I tested the pins in the closeup using the legend and never got any volts off of PS-ON or BL-ON individually. I was only able to get 12.3V on all 3 at the bottom when I jumped the top 2 (PS-ON and BL-ON).
    oh, and this is the power supply board: 810426667
    Any help appreciated.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Hitachi LE42H508 no power....
    What are your voltages in standby?
    • Bullykatz
      • Mar 2017
      • 6
      • usa
      That's the oddest thing... I could not get any readings on either of the top 2 pins even when jumped together. Yet the bottom 3 would read 12.3V ....
      I didn't even try jumping the top 2 pins on the replacement power supply,I unboxed it,swapped it in, plugged the TV in,and tested with pins connected to the ribbon and nothing.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Might try disconnecting t-con. When you power it on do you ever get any pson voltage
        • Bullykatz
          • Mar 2017
          • 6
          • usa
          You lost me... That'll require a much more detailed walk thru please. this is my 1st attempt at a TV teardown... I usually use a M/M on motorcycles or cars.
          TIA
            When you jump the 12V DIRECTLY to the PS-ON pin and the BL-ON PIN, Did you remove the connector going back to the main board first? If you did not then you could now have damaged the switched Transistors on the main board.
            • Bullykatz
              • Mar 2017
              • 6
              • usa
              By directly do you mean bridge the PS-ON and BL-ON with a tiny alligator? because that's all I did WITH the connector disconnected. The only testing with the connector in place was with the MM in DC, the blk probe on one of the GND pins and using the red probe on PS-ON, BL-ON and the 12.3 (x3) with no readings whatsoever. I tried using the frame as ground with no difference.
              • dskall
                • Oct 2016
                • 2905
                • usa
                So you only connected the ps-on and the bl-on together? Which will give you nothing because neither have voltage on them.
                • Bullykatz
                  • Mar 2017
                  • 6
                  • usa
                  I had watched a video online recommending to test this way...
                  Regardless of my poor testing, any suggestions?
                  Since I bought and replaced the PSU and still no change, what's the next step?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    If you are not getting a ps-on voltage when you try to power on then I would say it is mainboard problem.
                    • hardbox
                      • Sep 2013
                      • 22
                      The LEDs are bad. That will take the PS down. If you unplug the main. The 12v will stay. Is not the Main, is the LEDs. Trust me.
                      • nomoresonys
                        • 12207
                        • U.S.
                        Simple test, if tv has pullup resistors, backlight if working will come on and stay on, do it just like this, make sure tv is unplugged, disconnect powersupply board from mainboard, plug tv in turn it on see if backlights come on.
                        • nomoresonys
                          • 12207
                          • U.S.
                          http://www.shopjimmy.com/hitachi-810...upply-unit.htm is this the powersupply?
                          • nomoresonys
                            • 12207
                            • U.S.
                            Is possible you got a dud with the new/used powersupply board, testing always beats jumping to conclusions.
                            • nomoresonys
                              • 12207
                              • U.S.
                              https://elektrotanya.com/?q=keres Put your model number in and see if they have a service manual, always makes things easier with one.
                              • nomoresonys
                                • 12207
                                • U.S.
                                You were close, you need voltage, so jumper the ps_on with 12 v, with mainboard DISCONNECTED, then see if your voltages have returned.
                                • nomoresonys
                                  • 12207
                                  • U.S.
                                  You may need to jumper bl on ps on and 12 v. all together, not exactly sure on that.
                                  • nomoresonys
                                    • 12207
                                    • U.S.
                                    If you can't get your ps on voltage with all other boards disconnected and the powersupply jumpered correctly, then the problem lies with the powersupply. If you can't get the standby voltage, look towards the powersupply.
                                    • nomoresonys
                                      • 12207
                                      • U.S.
                                      https://www.youtube.com/watch?v=qxG3hmmvkJs
                                      • nomoresonys
                                        • 12207
                                        • U.S.
                                        n/a
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
