Samsung PN60F5500AF no picture. Resistors smoking
  • aasnowskate
    • 118
    • usa
    I have a Samsung PN60F5500AF Plasma that has no picture. It has sound.
    When it first came in, I put a meter on the buffer boards and had continuity from where it connects to the y main board and where it connects to the ribbon cables. I ordered new buffer boards and when I first unpacked them, I had the same reading. I contacted the seller and he assured me they were working. I thought I was testing them wrong. I installed the new boards and had the same result.
    Next I ordered a new set of buffers from a different seller and tested them the same way and had continuity again. I figured I was doing something wrong and narrowed my problem down to the Y main board.
    I ordered a new one and when I plugged it in, the resistors at the bottom of the Y main board ( R5084, R5097) started smoking. I replaced the resistors and they still smoked. I got another Y main and had the same result.
    When I remove the lower buffer board and turn it on, there is no smoke.
    Do I have bad buffers causing my problem?
    I will try to post pics of the boards soon.
  • aasnowskate
    • 118
    • usa
    Re: Samsung PN60F5500AF no picture. Resistors smoking
    Pics
    • aasnowskate
      • 118
      • usa
      Anyone have any thoughts? I feel like I have a bad plasma panel, but looking for a second opinion.
      • rccrasher65
        • Mar 2014
        • 625
        Your y-sus is probably bad, thats also not proper way to check buffer boards. search the forum to get proper way to test samsung buffers, plenty of threads here. Also need to get voltages, and compare the results to label on back of panel.
        • aasnowskate
          • 118
          • usa
          Thanks for the reply. I searched quite a bit and can't find a thread showing a different way of checking a buffer. This is the way I have always done. I have replaced the Y main and then again thinking I had a bad y main. Both times, I had the same result: smoking resistors. Not sure what to think other than a bad panel.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Pics
            The pictures are to small to see what is on the boards.
              09-07-2024, 05:50 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Dodgethis
              Samsung QN75Q6DRA, No Picture, Has BL, and Sound
              by Dodgethis
              Hello all,
              This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
              09-11-2024, 07:39 AM
