Panasonic DMP-BD87- Unit Stuck On 'Hello'
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Hello all. I got this BluRay player some time ago and it has a problem...
    Upon plugging it in, it does nothing. Pressing 'Power' switches it on. Upon powerup, it says 'Hello', does not output a picture, and the disc tray ejects and returns once. After that, I have to unplug it and plug it back in again to get a disc back. Pressing 'Power' once it's on will NOT power down the unit.
    What is going on here? Thanks.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • Stunt
    Hp Laptop Stuck on Hp protected by hp sure start screen
    by Stunt
    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
    screen that's it and stuck there. I left it until the following day and i still...
    09-02-2025, 01:51 PM
  • Junior††
    PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
    by Junior††
    Good Afternoon fellas,
    Issue:
    Disc is showing as not supported when a disc is put in.
    Here's what I've done, you can skip this if you just wanna know the question:
    - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
    - reflowed the disc drive connector
    -reflowed the chip in question (shown on image)
    - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
    Question:
    I...
    02-19-2025, 12:48 PM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • Ancient1
    I'm stuck . Panasonic TH-L32U20M panel's boards issue
    by Ancient1
    Hi
    The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
    Actions :
    1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
    1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
    Obviously the fault is from or on the Right, secondary board
    2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
    09-03-2023, 03:51 AM
