Parallel multiple secondary diodes - why ?
  • genuineguy
    • Sep 2015
    • 46
    • india
    Dear Experts
    I have seen that many SMPS circuits have parallel connected ( yes, physically different but parallel on the board)schottky diodes. There must be a reason for the same. I tried to search on google but could not get a technical explanation. Could you please help with the theory or some link to a document that describes the same ? I have a feeling that its got to do with something from snubber perspective and not just increasing current capacity
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Parallel multiple secondary diodes - why ?
    They share the current flow. If one diode was rated for 1 amp then paralleling 2 diodes allows for 2 amps to flow. 1 amp per diode.
    The only problem with this is that if they are run close to their maximum current rating, failure often results after a while.
    • genuineguy
      • Sep 2015
      • 46
      • india
      Thanks dick_barton.
      Going forward, I will address all as members and avoid using the word experts
      The circuit I am dealing with has 4 in parallel. Interestingly there is no RC snubber or any free wheeling diode at the secondary side. I am still struggling to see why its not affecting the primary side ( blow the mosfet) without the same
      • mariushm
        • May 2011
        • 3799
        It's also to lower voltage drop on each diode and may also be for heat dissipation...
        For example, the diode may have 0.35v drop at 1A but only 0.15v at 0.25A ... so put 4 in parallel to get only 0.15v drop on them instead of a full 0.35v
        0.35v drop x 1A = 0.35w dissipated on a diode ... or you can have 0.15v x 0.25a = 0.0375 w per diode ... or 0.15w dissipated over 4 times the surface, and with 4 times as many leads dissipating heat through the pcb traces as well.
        • CapLeaker
          Leaking Member
          • 8210
          Can we see some pictures?
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
            by momaka
            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
            http://www.rmac.kingwin.com/products.../abt_650MM.asp
            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
            What mostly drew me into buying it is its 2x PCI-E power connectors...
            03-29-2022, 11:34 PM
            Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
            by momaka
            This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
            Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
            Macron Power Technology Co. LTD.
            Let’s look at the PSU itself.
            The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
            06-02-2021, 10:05 PM
          • bearjumpjump
            Sfx 380watt failed mod
            by bearjumpjump
            So I try to modify this cheapo sfx power supply
            I change it's
            - main cap configuration to parallel rubycon 150uf 450v two pair
            -diode bridge in one package form with heatsink
            - add input inductor, X & Y cap
            But it won't start anymore lol
            5v sb is Okey
            Sc1605 got all of its voltage
            I got 320dc on main cap
            I got 14dc on output of middle small transformer (d9 those 1n4148)
            Secondary diodes is good (two pair mbr1645, f1620)
            Primary trannies is good (two 13700b)...
            07-09-2024, 12:18 AM
          • Nikolai Danylchyk
            Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
            by Nikolai Danylchyk
            Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
            Thanks in advance!...
            05-08-2025, 06:18 AM
