Phihips 47pfl5704d / f7 Back light not working
  • cwolford
    • Mar 2017
    • 46
    Re: Phihips 47pfl5704d / f7 Back light not working
    using retiredcaps tuts i'm doing some measurements. Here is T701 backlight
    here is the print on it:
    2130kp029c-f
    gl 47 fhd
    ny091106b
    here is the measurements
    1 to 2= 1.04 ohms
    1 to 3, 4, 5, 6= 0L seems to not measure at all
    2 to 3, 4, 5, 6= 0L seems to not measure at all
    3 to 4=23.94 ohms
    3 to 5=67.95 ohms
    3 to 6=91.89 ohms
    4 to 5=44.1 ohms
    4 to 6=68.05 ohms
    5 to 6=24.05 ohms
    • cwolford
      • Mar 2017
      • 46
      Like i said I dont know a lot, but Seems I have a bad MOSFET.
      KHB 5D0N50f
      all of them Q706-q709 have same readings but q706
      q706
      1 to 2= 14.92 ohms
      1 to 3= 2.109k ohms
      2 to 3= 2.116k ohms
      q707, q708, q709
      1 to 2 = .3190k ohms
      1 to 3 = cant get a lock DMM is seeking down from 20M ohms
      2 to 3 =Cant get a lock DMM is seeking down from 15M ohms
      Since this are the same somebody is bad. the question is who, then why.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        if the drain / source is shorted to the gate, then you have to look at the whole gate drive circuit too. Take the Mosfet out and check it again out of circuit.
        • cwolford
          • Mar 2017
          • 46
          I will remove it soon and retest. All the diodes seem to test good and all the other transistors on the broad seem ok.
          Anyone know of a place in USA to buy a replacement so i don have to get the whole repair kit.
          I have used mouser and digikey and ebay but Seems the KEC KHB 5D0N50f is old. I dont know how to find a new one that will have the same specs.
          • cwolford
            • Mar 2017
            • 46
            I could use some help finding the parts that need checked in that circuit. Yow do you guys know this is their like a circuit diagram or something?
            • cwolford
              • Mar 2017
              • 46
              I removed q706 and q707 with the heat sink as I could not remove screws at that angle. Q706 same measurements. Q707 all I got was 0L on all measurements.
              I know how to solder I was in and out quick NP all went easy, I don't think I killed it. What gives
              also was wearing esd strap
              • cwolford
                • Mar 2017
                • 46
                So I got to thinking to find the rest of the circuit as i dont have a diagram, I can just use the PCB traces and dmm to track it from the bad Mosfet. Is there anything hidden between the layers of PCB or should i beable to track by eye and maybe the help of the dmm?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4546
                  • Italy - Milan
                  #28
                  PSU boards don't has inner layers.. for the transistor you have to watch on distributor's site and select the one that meets or exceeds the original's specs as for Vds, Rds-on, Id, channel type. Vds=the more the better, Rds-on=the less the better, Id=more/better, channel=same. I think that if the board tried to switch on the B.Light then probably the drive circuit is ok but it stops for the shorted mosfet and goes in protection, if you don't know methods of testing the rest, try replacing only the mosfet.. without an oscilloscope you can't test much..
                  • genuineguy
                    • Sep 2015
                    • 46
                    • india
                    #29
                    To replace the MosFet some parameters to look for the replacement are
                    1. The Drain current must be equal or higher
                    2. The on resistance same or less
                    3. Vds same or higher
                    4. Vgs same or higher
                    I used these rules and have replaced MosFets with commonly available IRF series and have repaired the board
                    Also, the first step is to search the internet and download the service manual for your TV. These days its available. I could get one for mine and it helped me a lot. Neat circuit diagram etc. If you don't one for yours exactly, see if there is one for the nearby models as the boards are more or less similar.. atleast somewhat ...
                    • cwolford
                      • Mar 2017
                      • 46
                      See i know a circuit will only pull the amps it needs. I also knew that the resistance had to be near the same, anyone know how much wiggle room i have?
                      What i dont get is the voltage for the gate / drain. I know there is wiggle room but Too much cause heat and part blow, too little is bad too the meaning of brown out, not sure what this does tho.
                      thanks for the replys
                      • cwolford
                        • Mar 2017
                        • 46
                        so i'm not even %50 sure, but based on what i have come to understand from chatting here and the spec sheets.
                        The circuit applys voltage to the gate of the mosfet to control it
                        That voltage should be 10v, but no more than 30v right?
                        Next
                        The source should be ground and then the drain seems to be the voltage from the 450v caps.
                        So I should be able to test to make sure there is ground at the source, 10-30v at the gate, and cap voltage of at the drain?
                        It seems it seems the mosfets control the current as compared to hooking the transformer up straight to the caps right?
                        • cwolford
                          • Mar 2017
                          • 46
                          seems i did not kill that MosFet the holes in the the pcb have the measurements with our with out the Mosfet.
                          Seems that mosfet is bad to seeing its all 0L yea? If anyone know of anything else i should check because of the bad mosfet plz let me know.
                          thanks
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4546
                            • Italy - Milan
                            #33
                            First.. please use commas.. after, i'm not comfortable using ohms to test mosfets, but i believe it's normal 0L all the way, there's many websites explaining how to test them, search "mosfet test", normally mosfets becomes shorted so you read very low ohms or volts in some ways.. most of the times D-S in your case..
                            • cwolford
                              • Mar 2017
                              • 46
                              Will look into to it as I get some free time. Thanks. Why are you not comfortable>? Is it like a fast and dirty way? Like not 100% etc..
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4546
                                • Italy - Milan
                                #35
                                It's only that i have learn only to use diode test of the dmm, i dont know the values in ohms..
                                • cwolford
                                  • Mar 2017
                                  • 46
                                  thanks all, got the time to do it.
                                  $6 in MosFet. fixed it. IT boots up, back light flickers, but then after warm up is fine.
                                  been working 3 months.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4546
                                    • Italy - Milan
                                    #37
                                    CCFL lights can be at end of life, your PS board can break again if you don't care of them..
                                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                      I am comparing them to a brand new one that I installed
                                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                      I going to let it run for several days before I remount back on the wall next to the...
                                      09-05-2024, 06:48 PM
                                    • PNI E.
                                      tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                      by PNI E.
                                      hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                      02-20-2025, 08:36 AM
                                    • koby058
                                      vostro comes up with back light but no picture
                                      by koby058
                                      Hi people!!
                                      The owner said it showed bad picture once in a while (attached)
                                      I see that there is back light but no picture.
                                      I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                      Also attached schematic and BDV
                                      LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                      07-13-2025, 01:03 PM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • GLISIT
                                      by GLISIT
                                      01-16-2025, 02:29 PM
