LG 32LN 540B TV Sound but no video
  • CostasCostas
    • Feb 2017
    • 20
    • Cyprus
    My wife recently fell from a chair whilst "spring cleaning" and splashed our LG TV with the contents of a nearby mop bucket. Not much water and only on the screen.
    We left the TV for a few days to "dry out" but all we have is sound and no video. The backlight seems fine but no picture.
    The TV is an LG 32LN 540B.
    Google suggests this is quit often a problem with the t-con board and I have attached a photo to this post. The part reference is 6870C - 0442B and as far as I can tell from the various test points on the board it checks out OK.
    Also attached is the power board, EAX64905001, and again the voltages seem to check out on P201 from the top as 0, 12, 12, 0, 25, 0, 3, 3 and 3.
    Finally the video board is NC4.0/LD36B, attached, but I don't have a clue what to check on this board. Obviously some of it works as the power board feeds the video board which in turn feeds the t-con board.
    Any ideas how I can work out what part of the TV is broken?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 32LN 540B TV Sound but no video
    You could check what DC voltage you have on both sides of the smd device marked TK closeby CN1 (picture 1)
    • CostasCostas
      • Feb 2017
      • 20
      • Cyprus
      @dick_barton the voltage is 11.92 on either side of TK. Presumably this is OK.
      Anything else I can try?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Yes that's OK. Is the tcon at the bottom of the set?
        • CostasCostas
          • Feb 2017
          • 20
          • Cyprus
          Yes with the infrared sensor directly below it. Power board is centre left and video board centre right.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            The Tcon has quite a number of test points you could measure.
            If you could list them I'm sure someone can tell you if the Tcon appears to be OK or faulty
            VCC, VCC_ 33, VGH, P12, HVDD etc.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              There will also be a narrow interface circuit board which the tcon connects to that is attached to the led panel. This may still have water on it. There is also a possibility that if there are smd fuses on these boards which also need to be checked out.
              • vinceroger69
                • Mar 2012
                • 6714
                yes as above post water may of got onto the lcd panel pcb or even the lcd tab bond area so wort stripping down and having a close look.
                • CostasCostas
                  • Feb 2017
                  • 20
                  • Cyprus
                  I had checked the obvious 3.33 and 12V but looking at the full set it doesn't look right.
                  This is what I have:
                  VCC 3.3
                  VCC_33 3.3
                  VGH 0
                  P12V 11.89
                  HVDD 0.96
                  VIN 11.89
                  VDD 0.30
                  VGL MINUS 5
                  WP 3
                  SCL 3.3
                  SDA 3.3
                  SOE 0.66
                  Is the t-con dead? Can I repair it or do I just replace it?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    depends you need to check the long lcd panel pcb first for water damage blown fuses etc as this may cause voltage issues on the tcon etc its the pcb the lower ribbon cable of the tcon joins onto.
                    • CostasCostas
                      • Feb 2017
                      • 20
                      • Cyprus
                      @dick_barton is the interface board what a layman like me would call the infrared sensor board? Tried with and without the infrared sensor board connected. Does it need to be connected i.e. should the TV work from the physical buttons on the TV?
                      @vinceroger69 what does the "lcd panel pcb" and the "lcd tab bond area" look like?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        see below post as its explaned better with a picture
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          The two ribbon tabs go to thin printed circuit boards which are then attached to the lcd panel via more flexible ribbon tabs. The circuits boards run along the length of the LCD panel.
                          You need to take extreme care when handling the circuit boards so that the ribbons are not damaged or pulled away from either the circuit board or the LCD screen. If this happens then the set has had it.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            VCC 3.3
                            VCC_33 3.3
                            VGH 0
                            P12V 11.89
                            HVDD 0.96
                            VIN 11.89
                            VDD 0.30
                            VGL MINUS 5
                            WP 3
                            SCL 3.3
                            SDA 3.3
                            SOE 0.66
                            What do you have for VGH_L, VGH_F, ODD, EVEN
                            It looks like you have a problem with VGH missing, but if someone else can please confirm.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              It looks like you are missing VGH but if someone else can please confirm.
                              a quick read of this link looks like vgh should be 27v for a 32 inch set
                              http://tvrepairsolution.blogspot.co....lcd-panel.html
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Yes, I've seen VGH given between 15 to 30V and VGL between -5 to -15V
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  maybe waters got onto that panel pcb and shorted a cap/etc out etc dragging vgh down?
                                  • CostasCostas
                                    • Feb 2017
                                    • 20
                                    • Cyprus
                                    I'll see if I can find VGH_L, VGH_F, ODD and EVEN but I don't recollect seeing them on the t-con.
                                    I'll also check out the LCD panel board.
                                    Thought I had already stripped down the TV
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      With a bit of luck it may only be a faulty Tcon damaged like you say when water was splashed and with all likelihood shorted some components on the panel tab pcb. Hopefully nothing else is damaged.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        They are shown in your first picture.
                                        • Exim
                                          ASRock N100M, no picture no boot, but semi-alive
                                          by Exim
                                          Hi guys,
                                          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                          ASRock N100M special features:
                                          - CPU soldered to board, small Intel 12th gen
                                          - iGPU
                                          - four POST LEDs
                                          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                          Symptoms:
                                          - no picture/signal on any of the display connectors,...
                                          04-01-2025, 02:36 PM
                                        • Aimbit
                                          JBL Flip Essentials - Bluetooth not connecting after a fall - video of board
                                          by Aimbit
                                          video: https://www.youtube.com/watch?v=S-xBu7m6SwE
                                          Hi all. I was given this JBL Flip Essential speaker that 'fell from about 8 feet' and then the bluetooth would no longer function. It seems to power on normally and responds to button presses, but it will not showup on bluetooth for any device I try to connect to it.
                                          The bluetooth daughter board has a 26mhz oscillator that I could not get to read the proper frequency so I tried replacing that to no avail. Thought maybe something was wrong with the bluetooth IC it's connected to, so I tried replacing that as well. None...
                                          10-28-2024, 09:29 PM
                                        • JRade
                                          Audio video receiver KENWood KR-V990D,no sound
                                          by JRade
                                          When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                          The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                          I replaced the capacitor C303/0.047F, nothing changes.
                                          I'm asking for help, what should I do next?
                                          Thanks in advance!...
                                          08-05-2025, 10:23 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
