Sharp 70" model LC-70LE733U 2-5 blinks
  • anthony_c
    • Jul 2019
    • 49
    Re: Sharp 70" model LC-70LE733U 2-5 blinks
    Originally posted by ricsgone
    Ok, I'm new to the forum, but I've been reading the posts and I'm still having issues with my Sharp LC-70LE733u with the 2 long/5 short lights. I have replaced the main board, the power supply board and the LED address board with no success. Also, when I attempt to get into the diagnostics menu by holding the volume down and input buttons, it doesn't work. It went in one time and then would not repeat. I have a t-con board coming, so I'm getting a bit harried with this thing. Any other suggestions? By the way, I'm pretty technically adept as I build, repair and maintain PC's and laptops. Thanks for any help you can provide.
    any update on this? i have the same model and can't get it to turn on. Clear the 2-5 code and still nothing. Even with cable from Tcon disconnected.
    • advant
      by advant
      02-03-2020, 12:25 AM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • moltensolderlabs
      Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
      by moltensolderlabs
      Hi everyone. [Sorry for the long, detailed post in advance].
      I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
      10-09-2020, 12:01 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
