Panasonic TH50U30A
  • chrismurphy
    • May 2014
    • 251
    • australia
    Panasonic TH50U30A
    Repaired this tv with new SD and SU boards and was all good ,and eventually sold it
    2 months later the set is turning off after 15 mins , leaving only a green light on the front panel ,no blinks , and no response from the remote
    anyway turning off at the mains and then on works again , but shuts down again 5 to 15 mins later
    Reduced the Vsus voltage from 215 to 210 seems to have fixed the issue
    Can anyone tell me the correct Vsus voltage for this TV as there is no sticker on the panel
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH50U30A
    Vsus Lo = 215V. Strange fault , have not seen that.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Check for cold solder joints on the sus fets and bad grounds that can also cause that.
      • Buzztv
        Panasonic TC-P42S60 Plasma,how to check Vsus
        by Buzztv
        This is my first post in attempting to keep my beloved 2013 Panasonic plasma tv going.
        About 6 weeks ago the tv was turned on but then immediately shut off. There was no recent power surge or popping noise or any other symptom.
        I checked all of the obvious things and decided to try a replacement power supply board (PSS in Panasonic lingo).
        I would like to check the Vsus but this is one of the final models and at that point Panasonic did not indicate the Vsus and Vad voltages inside the chassis. It looks like they were discouraging people from making adjustments....
        10-27-2019, 01:24 PM
      • Amraks
        Panasonic SA-MAX770 (not turning on)
        by Amraks
        Hey all its been awhile since I have needed to post here.
        Panasonic - SA-MAX770: Symptoms not turning on
        Power Supply
        C1403 has 330v
        IC1402 Looks perfectly fine no blown out holes.
        C1601 has 3.3v
        CN1851 Has its 3.3v but no 15v all I am getting is on the 14v rail is 0.400v
        Not sure where I should be looking next for this any help would be appreciated...
        10-04-2022, 12:12 AM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
