Insignia NS-32L430A11 Backlight problems
  • kevinm34232
    • May 2012
    • 1884
    backlight was shutting off after about 30 seconds of TV turning on. Found T401 was burned. Ordered a kit from shopjimmy, the transformer was slightly different part #, original 8TC00569. Replaced with 8TC00588.
    Then R721 and Q701/702 burned up. They were part of the kit, replaced them and they burned again.
    Is this transformer not compatible? All other parts are the same in the kit.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Insignia NS-32L430A11 Backlight problems
    Have you checked that there is not a problem with the wiring from the transformer to the tube shorting to the case which may have been the cause of the original fault and also responsible for the second fault?
    Perhaps checking the CCFL connectors resistance.
    Have you checked the capacitors C40x
      It can be due to worn out lamps and drawing too much current from the transformer HV winding.
      Those little blue ballast caps are OK? No leakage resistance on them?
      • kevinm34232
        • May 2012
        • 1884
        Is it weird that before, with the original transformer, it would stay on for 30+ secs, then shut off, never blowing any other components?
        Now it violently burns up the resistor smoke and flames!
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          All I can think of is to compare the winding resistances and see if the replacement compares with a good transformer.
          • kevinm34232
            • May 2012
            • 1884
            I got a new power/inverter board which works and now I can see a dark row where it looks like a bulb is out.. Bummer
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              That could be because the CCFL tube has slipped out of it's connectors.
              • Wolf1977
                general question when a mosfet on primary of transformer is burned
                by Wolf1977
                hi
                in a welding machine i had a mosfet and four components wich connect with it burned
                i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
                i dont understand whats happen wrong
                more particular on the schematic q11p01 mosfet q11p02 tranzistor
                three paralel resistors had burned q11p07 zener shunt q11p08 open
                when i changed all these shunts q11po7 mosfet and tranzistors
                maby the transformer has problem on your opinion or something on...
                08-19-2023, 01:27 PM
              • learnmore
                Help choosing replacement transformer for Levoit 600S SMPS
                by learnmore
                Hello Community,
                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                Peace
                LM...
                11-04-2025, 09:35 AM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • mikey5791
                Is it possible for transformer substitution?
                by mikey5791
                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                My questions are
                1. How do i test to see if the transformer is in good working condition?
                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                Hope you guys understand what i was asking. My intention is...
                11-03-2022, 02:11 AM
              • dennis_elx33
                3PHASE STEP-DOWN Transformer in Check
                by dennis_elx33
                Hello All,
                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                Problem statement: Power tripped Off
                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                Action Done:
                1) Replaced the faulty parts with good spare.
                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                12-02-2024, 06:52 AM
