Toshiba LCD TV horizontal lines
  • kodiac
    • Jul 2010
    • 116
    I have a Toshiba 32C120U that has a normal LCD screen when turned on.
    After a about a minute horizontal lines begin to appear on the screen which eventually covers the full screen with mainly horizontal lines with ghostly vertical lines.
    I would appreciate knowing if someone has seen this problem before and can tell me a solution or if someone has any idea what is causing these lines to appear on my TV?
    Thank You
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4538
    • Italy - Milan
    Re: Toshiba LCD TV horizontal lines
    The problem is between Tcon and the panel connections, but the first is integrated so you cannot do near anything.. apart trying to preheat the tcon in many points and see when pops up the defect, if you have luck you can isolate the culprit.
    • kodiac
      • Jul 2010
      • 116
      That's a huge help sir.
      Thank You
      • kodiac
        • Jul 2010
        • 116
        Do you where I can get a diagram or schematic for the
        Tcon and the panel connections on this TV?
        Toshiba 32C120U
        Thank You
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4538
          • Italy - Milan
          There's only few schematics out there on net about some models of AUO panels, yours is a Samsung panel so nothing..
          • kodiac
            • Jul 2010
            • 116
            Thank You
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              You may be able to apply the Cut-off Method......but your soldering skill has to be good as you may have to re-solder cut lines in the process.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4538
                • Italy - Milan
                Andrew, first of all i don't know to which method do you refer but, you have done success in that method? what do you use to regenerate lines, enameled wire? You can't solder on tabs, you fix them with conductive paint?
                • kodiac
                  • Jul 2010
                  • 116
                  These TV's are disposable?
                  Any LCD TV's on the market in which you can replace the T-Con boards?
                  All LCD TV's have embedded T-Con to LCD panel ribbon cables?
                  Horizontal lines on a LCD TV can not be repaired except for the Cut-off Method?
                  Thank You
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Thank You
                    There at LCD TVs that have replaceable T-CON Bds on the market. Perhaps you have not seen any??..I have repaired LCD TVs using the 'cut-off' method that were previously diagnosed as bad Panel issues. With this method you are actually removing or cutting off the signals to a certain section of the panel...the picture will be visible but the quality would have diminished a bit but mostly undetectable....so technically it still is a bad panel issue but the TV would be saved from the dump and still be usable.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4538
                      • Italy - Milan
                      This technique isn't used only for the vertical flicker/double image issue?
                      • budwich
                        • Jul 2015
                        • 3097
                        it is unlikely that multiple horizontal lines on a set is a side driver issue and is more likely some other component such as a tcon or cabling. Look very carefully at the cabling first to ensure that it is properly connected ... if in doubt, clean the connections / connectors. IF the tcon is replaceable, then it is also a possible candidate. Since your problem appears to be "time sensitive", perhaps using a heat gun / hair dryer to direct heat towards a portion of the card / set / connector might yield a clue as to where the problem lies.
                        further disconnect one cable at the tcon, input a well known signal to the set, what happens? try a different cable. Go from there.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4538
                          • Italy - Milan
                          "IF the tcon is replaceable, "
                          No..
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Since the T-CON is not replaceable and there are no external side drivers look at the T-CON/Driver Bd again and see if there is any possibility of a slightly couching component to the chassis or metal. You issue does seem heat related and therefore the TFT in the Panel could be overheating with time also indicating a Bad Panel.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4538
                              • Italy - Milan
                              what is "couching"? Anyway if you at tv cold, heat the glass ic's on the tabs before switching on, with hairdryer, you see if are them faulty , if yes, remeber, i saw on youtube, just in Canada it exists a lab. that changes those faulty tabs..
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                Sorry not 'couching' but it should be 'touching'......
                                TFT are inside as part of the glass a panel and cannot be seen or replaced as apart from the Driver IC on the FPCs
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4538
                                  • Italy - Milan
                                  I don't understand, is not possible all tft's in a panel goes bad, what happen if only a tft goes bad? Do you mean that some connections inside the glass breaks with the heat? It's not possible is a multiplexer/driver/glass ic? Them are replaceable..
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • oxi1158
                                    Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
                                    by oxi1158
                                    My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
                                    I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
                                    10-09-2020, 08:37 PM
                                    09-06-2024, 05:27 AM
                                  • Ihandyrepair
                                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                    by Ihandyrepair
                                    Hi guys
                                    I just started fixing 4k TV few months ago. so I am still learning a lot
                                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                    then it started to show the ghosting white image.
                                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                    it has 3 thin small boards at the bottom of the...
                                    12-05-2022, 04:18 PM
                                  • netgearnetgear
                                    TOSHIBA 32C100U1 - Faulty display (double images and lines)
                                    by netgearnetgear
                                    Good day all,
                                    I have a Toshiba TV, model 32C100U1 that turns on, displays fine for 5 min, sometimes 10 min and even 25 min then it starts to show double image, wrong colours together with lines as seen in the attached. I have measured and documented the tcon voltages both when the Television works fine and when the problems described occurs. It is important to note that the voltages are the same on the tcon board. The LVDS cable, tge panel ribbon all test good. I resoldred all the main ic's connections pins, connectors and even reflowed gamma chip. I tried to block some of the...
                                    10-27-2025, 08:07 PM
