Could Coil Whine in LCD TV be poor circuit design?
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Hello.
    I recently bought a store return Samsung 32" LCD TV at a great discount.
    The TV set is great and perfect in every detail except one:
    After about an hour, a loud whistle noise starts coming out of the back of the set.
    This condition is all over the internet, with Samsung replacing coil chokes or power supply boards all over the country. The power supply boards are cheap and readily available. I even managed to track down the replacement coil choke.
    Removing the back cover and listening around with a soda straw revealed a noisy choke coil on the power supply board. All of the caps are Samwha WL and WB low and ultra-low impedance.
    Replacing the coil reduced the noise but did not eliminate it.
    Replacing the caps with UCCs and Rubycons had no effect.
    While the board was out, I noticed that the inductor does not appear to have a primary capacitor! The circuit trace goes directly from the switching transistor to the coil. The trace leaving the coil does have a cap on it.
    Could Samsung be asking too much of a coil to dampen all this bumpy electricity? Apparently, because the coil sure doesn't like it very much and doesn't mind saying so.
    I was wondering if drilling some holes and adding a capacitor would be a good idea. Probably not, as I lack the understanding and talent to choose a suitable capacitor rating and type.
    I also noticed that this board has an "A" revision and a "B" revision board is available. Maybe I should just get the newer version? It's not too expensive, the TV set is astounding and the the price I paid was way too cheap not to keep.
    Any ideas about this circuit design? Or about my observations?
    Thanks for any ideas,
    Keri
    added: The coil in question is a wire wound toroid with heatshrink tubing covering it. The original coil gets very hot, the new one less so.
    The More You Learn The Less You Know!
  • Wizard
    • Mar 2008
    • 2296
    Re: Could Coil Whine in LCD TV be poor circuit design?
    Contact your samsung's authorized servicer for a bulletin to replace this coil that emit whine noise with a redesigned coil. They will replace that coil or give it to you for few dollars and your TV will go quiet once again.
    Cheers, Wizard
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      Cheers, Wizard
      Hi Wizard
      Ummm.... The coil was $6 and change. Plus shipping. Didn't you see that I already replaced it? It did reduce the noise quite a bit and stays quite a bit cooler than the old one.
      Did you have any thoughts on the circuit design?
      Keri
      • Wizard
        • Mar 2008
        • 2296
        the best thing is take this coil out and dip this in varnish and let it dry, then dip 2nd coat and let it completely cure. Reinstall it.
        Then look around and see if you can futher isolate other source of noise and do the same dip on other coils or transformer.
        Also check all capacitors to make sure there is no bad caps.
        Cheers, Wizard
        • Gjackson
          ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
          by Gjackson
          Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
          01-13-2024, 10:34 AM
        • 90Ninety
          Coil Whine , buzzing, identifying parts R9 Fury
          by 90Ninety
          I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
          I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
          Perhaps likely is that I am missing something else it could be , here is a stock picture...
          12-15-2022, 04:18 AM
        • Uranium-235
          SMD coil whine "chirps"
          by Uranium-235
          Does anyone have high frequency sensitivity hearing and a motherboards have tons of sounds coming from it? Is this just coil whine en masse? When data to the SSD has high I/O I can hear the clicks and chirps. Same with when the graphics drive inits. Network adapters, chirping after I connect the cable
          I can hear everything. Every time I put my ear to let's say an open Shuttle XH series pc (currently working on) in the next room it sounds like I'm in the middle of a the fucking public bird aviary
          Of course this isn't just the shuttle, though I think the small case...
          07-10-2023, 10:06 PM
        • Jumme
          Boston Acoustics Soundware 5.1 SUB: Agonizing coil whine!
          by Jumme
          So. Had my Boston Acoustics subwoofer for 4 years and it had a terrible coil whine squeal from day one.
          I RMA'd it twice, but both times it came back (after a 6-8 weeks return time) and had the exact same problem.
          Said they "swapped the amplifier module". As it didnt help, personally I feel more convinced its the PSU module. Company now bankrupt and I cant stand the noise:
          Its a high pitch coil whine tone -it's terrible agonizing, when worst, I hear it clearly 4-5 m from the Sub (because sits in corner).
          It wines without RCA input....
          02-14-2021, 04:03 PM
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
